scary vibration on the hwy
  • tonytony
    Knee deep in poopie
    • Jan 2004
    • 3498
    well my steering wheel shakes violently when cruising on the hwy speed around 85mph, but its fine around 60mph nothing too bad. Also my steering wheel has some play, could the wheels be shifting left to right because of the extra play in the steering wheel? I know it's not my bushings because I was just under there a while ago and they're worn but still in decent condition. Could it be something loose with my steering rack? thanks
  • rayz
    • 494
    check your tie bar bushings. when the car is parked, grab one of the front wheels and try to shake it side to side. if it moves, youre tie rod bushings need to be replaced. or the entire tie rod assembly. id just check all the bushings up front.
    FOKAI DA'MA'SHI'I ENSANE GRAPPING INT.
    • M-technik-3
      • 18946
      Ball joints, tires throw a wheel weight? Brakes bad? many symptoms.
      • tonytony
        Knee deep in poopie
        • Jan 2004
        • 3498
        hmmm actually it does move, and for the loose steering wheel how is that fixed?
        • christophbmw
          • Mar 2004
          • 363
          go balance your tires. one of your wheel weights might of fallen off. thats prob why its so sudden. if that doesnt do the trick then you might have bad tie rods.
          '91 318is
          • Jon325i
            • 6934
            One thing worth checking are the wheels themselves. More specifically, are any of the wheel weights loose/missing? One way to determine if this is the problem is swap your front wheels & tires with the rear then go for a spin and see what happens. If the steering wheel vibration is gone, go get all your wheels rebalanced.
            I had something similar happen to me once a while back. I was worried it was some kind of pricy fix. Turned out to be an out-of-balance wheel. $10 fixed it.
            Jon
            Rides...
            1991 325i - sold :(
            2004 2WD Frontier King Cab
            RIP #17 Jules Bianchi
            • tonytony
              Knee deep in poopie
              • Jan 2004
              • 3498
              I still have my wheel weights, but I'll just take it back to the shop where I got it and get it rebalance and see if that helps any.
              • chesster6969
                • 321
                How many miles on the front steering/suspension components.
                I replaced all my front suspension components, plus bushings and tie rod ends, and control arms. The new components have revealed that the steering rack is loose and needs to be replaced.
                I had the shaking steering wheel/ shaky tracking on my car when going about 60mph.
                Any clunk sounds when turning?
                • tonytony
                  Knee deep in poopie
                  • Jan 2004
                  • 3498
                  I have about 98k on it, and the only time it clunks is when I turn into an inclinded driveway.
                  • chesster6969
                    • 321
                    You could have a bunch of loose components then. I sure did. Let it go to far (lipe the PO did) and youll be replacing a lot of things.
                    Check the Tie Rod ends for looseness and also the control arms like Rayzs suggested.
                    Your steering wheel shaking will improve once you fix the steering components.
                    • Saul325is
                      • 819
                      Balancing will help, alignment will fix it. Same thing happend to me, you can feel the vibrations in the steering wheel especially.
                      -Saul
                      Saul
                      01 330ci Daily Driver
                      89 332is Auto-x Friend
                      95 M3 *SOLD*
                      87 325is *SOLD*
