Best way to remove all this deadener?
  • Firestorm
    • 795
    I've started attacking it a bit with chisels/screwdrivers etc, but it's pretty tough shit.
    Would a heat gun free it up a bit? Then some xylene or something to clean it up?
    It'll all the painted over with lizardskin eventually, so i want it to be smooth as.
    Lsx/t56 Swap progress |----------| .0000000005% - Well below poverty line.
    Getting purists panties in a knot since 2007. ;)
    E30 count = 6! :shock:
  • NitroSpazzz
    • 64
    I removed mine a while ago without too much trouble. I used a heat gun and scraper. Another option is putting dry ice on it, let it sit for a could minutes then move the ice and hit it with a hammer. Supposedly the stuff just shatters apart if you do this.
    Every Gram Counts
      I removed that stuff from my track rat with an air chisel. That's a fast way to do it, but it runs the risk of damage to the sheet metal if you aren't careful. A safer, if slower and messier, way is to use a heat gun. Once the sound deadening is out mineral spirits will remove the residue.
      • Firestorm
        • 795
        Air chisel sounds a bit brutal :p The dry ice idea is cool too (pun lol) I'll go out and buy a heat gun tomorrow and see how it goes.
        Thanks
        • Farbin Kaiber
          Lil' Puppet
          • 29502
          dry ice really works, just put it on, let it freeze, then remove with chisel and hammer.
          • asubimmer
            • 6482
            I just used a scraper tool thats made for stuff like this....
            • StereoInstaller1
              GAS
              • 22679
              Apparently, if you pick up your E30 with a forklift, that shit just shatters.
              Of course the floor is not too nice after that, but yeah.
              Closing SOON!
              Thanks for 10 years of fun!
              • Firestorm
                • 795
                Omg rly?
                • Farbin Kaiber
                  Lil' Puppet
                  • 29502
                  oh shiv.
                    Oh it is, but golly its fast. I took all of that stuff out (cabin & trunk) in a couple of hours. There were a couple of places where I got carried away and did minor sheet metal damage, but those were easy to fix. A couple of hits with the MIG and a bit of metal filled body filler made them disappear.
                    • hendrixvodu
                      • Jan 2007
                      • 2514
                      i wouldnt get ride of it if you are planning on snow use...because i noticed every place bmw put it , is where the early models seemed to rust....and i noticed even at junk yards the ones with the dead shit in it dont have floor rust....
                      but thats my opinion
                      -His-
                      87 e30 325i
                      87 e24 m6
                      05 e83 x3
                      94 e32 740i 5spd
                      -Hers-
                      89 e30 325i
                      18 f48 x1
                      • robtech
                        • Sep 2007
                        • 217
                        dry ice is the best method by far...get a big block of it...break it up into pieces and scatter it on your floor, let it chill for awhile then clear a space away and go to town with a hammer and chisel...it popped right off in my rx7 when i did it...havent done this to my e30 yet but it should be the same. by far the easiest CLEANEST way...the heatgun method makes a sticky mess
                        beware of attack squirrels
                        • whiltebeitel
                          • Apr 2007
                          • 2098
                          I did the heatgun method on an E46 M3, and the heatgun+100 degree heat = big suck. you have to go to town with the mineral sprits afterwards, but it's not hard, took me about 6-8 hours to go from full deadening to clean as a whistle.
                          '89 325i track sloot
                          '01 530i daily
                          -Enginerd
                          • StereoInstaller1
                            GAS
                            • 22679
                            So no go on the forklift, huh?
                            Closing SOON!
                            • Firestorm
                              • 795
                              Dry ice is too hard to get here unfortunately, so i'm going out to buy a heat gun now.
                              I'll pass on the forklift idea... :)
