Replacing motor mounts
  • Jordan325iC
    • Aug 2005
    • 1697
    Well, looks like one of my motor mounts is broken, so I'm replacing both of them. I am using the floor-jack + piece-of-wood method I suppose, unless anybody has a better idea.
    Is there anything I need to disconnect before I start jacking up the motor?
    '88 325is
    VP UT of Austin Autoholics
    BMWCCA 380364
  • PУCCKAЯ_e30ka
    • Jan 2006
    • 1226
    nope, just jack it a little and replace them!
    • Mike325
      • Mar 2006
      • 3685
      Just watch out for the engine ground on the driver's side.
      Originally posted by Kershaw
      • Sean
        • 5793
        Yea, jack it up, it should work. I did that, and just had to have a couple friends tilt my engine so I could get the engine mounts in just right. Keep an eye on everything, if its getting caught, it will start to lift the car!
        - Sean Hayes
        • tjts1
          • May 2007
          • 1851
          Don't forget to leave the hood open. I dented my own hood from the inside out. Not my proudest moment.
          • bolognablake
            • Jun 2007
            • 258
            Nice.
            Reminds me of when I was cutting a space in my hood for a vent and I forgot to cover the windshield. For the next few years, I had about a hundred little pits on the windshield.
            • Jordan325iC
              • Aug 2005
              • 1697
              God damn. How do you get the top nut off the driver's side motor mount?? There is just enough room for a wrench, but not enough room to give it any torque. What did you guys do?
              '88 325is
              BMWCCA 380364
              • JonathanJ.
                • Aug 2007
                • 145
                Extensions on a socket if I recall correctly.
                  • 37832
                  You need a long extension.
                  Also, watch the fan on the radiator depending on how high you lift the motor.
                  Classic BMW Specialists
                  Grover Beach, CA
                  www.BimmerHeads.com
                  • backtrail69
                    • Jul 2005
                    • 4471
                    I usually just pop off the shroud, and if you have a strut brace take that off.
                    :: PNW Crew ::
                    '87 325 4dr, '74 2002
                    • Ben Carufel
                      • Jun 2004
                      • 5248
                      Where are you jacking against the bottom of the motor? Oil pan?
                      • strad
                        • Jan 2007
                        • 241
                        ^^ Ohh man, I'd go with the transmission-motor interface instead, unless your oil pan gasket is brand new. Otherwise you might be buying yourself into another job!
                        The current fleet:
                        1992 325ic: 148k-171k miles
                        1999 Chevrolet Tahoe LT 4WD, 114k-142k miles
                        1984 MasterCraft Stars and Stripes Powerslot (not a car :D) PCM Ford 351W, 904 hours
