DIY clutch stop problem...
  • DanGillan
    • Mar 2004
    • 4061
    so i went to Home Depot, got all the parts for that DIY clutch stop thing. I made it, went to go remove the old one... damn, rounded off that plastic piece of shit. Then I went at it with pliers, thought I had it, but NOPE! it was that shitty plastic disc thing breaking off from the plastic bolt in the thread or whatever. So now basically I cant get the "bolt" out of where the new clutch stop threads in. There isnt enough sticking out to grab on with pliers. Anyone have any ideas? thanks in advance for any help.
    Dan
  • bwanac
    • 3354
    Good job. :up:
    Drill out the center of it very carefully?! :?
    This is an interesting dilemna.
    • bimmerphile
      • 3495
      you could drill it out, but im not sure on how you'd fit the drill in behind the clutch pedal. Also, if you hit that area with a heat gun as you yank it would help I'd imagine.
      • DanGillan
        • Mar 2004
        • 4061
        i can barely grab onto it, so i dont know how heating it and pulling would work. Damn, this sucks. I dont have a heat gun, will a hair dryer work? thanks for the help guys.
        Dan
        • Bryson
          • 1490
          take a dremel, cut a groove and turn it out with a plane screwdriver
          This is kind of a funny problem though
          My clutchstop has an allen head and the washer welded to it clears the allen so it's real easy to remove. Don't make a clutchstop unless you use something rubber on the end, or you'll sound like an old ghia when you shift ('tink')
          • kencopperwheat
            King of Kegstands
            • 14396
            Does it move in the threads easily? That is, if you were able to grab it would it turn? If it's not locked in the threads, I'd dremel a slot in it and turn it out with a screwdriver. You *could* try and epoxy a stick or something to it and then turn that.
            Originally posted by Gruelius
            • DanGillan
              • Mar 2004
              • 4061
              yea, i used one of those rubber chair leg protector things. ill try drilling it out now...
              this sucks!
              ken: it doesnt turn at all, its locked in the threads
              Dan
              • bwanac
                • 3354
                Glad you're doing it though after testing my clutch stop last night?
                You know it is worth it! :D
                • DanGillan
                  • Mar 2004
                  • 4061
                  alright... after 45 minutes of drilling the fuckin plastic out of the fuckin hole, then adjusting the fucker for about an hour, it's finally done. One thing though, its not really an adjustable clutch stop anymore, it's pretty much only adjustable in my garage, not by hand. there was still plastic in the threads, so i pretty much just used all my strength and forced the bolt in, its fuckin tight. THANKS for all your help everybody!
                  Dan
                  • skat 325is
                    • 296
                    The clutch stop mod cant be made on 84 - 87 e30s right ?
                    • bwanac
                      • 3354
                      Yes, it can! I have one on my 87.
                      Dan, are you sure you got the right bolt size and thread ct. and stuff?
                      • DanGillan
                        • Mar 2004
                        • 4061
                        i dont know, I think I did. the thread may have been wrong, but what's done is done I guess. haha
                        Dan
