What are the proper names for these 2 parts?
  • Jand3rson
    • 37587
    Pulled from fuel tank under passenger side of rear seat.
    Pulled from fuel tank under driver side of rear seat.
  • rayz
    • 494
    pics no werkie?
    FOKAI DA'MA'SHI'I ENSANE GRAPPING INT.
    • kencopperwheat
      King of Kegstands
      • 14396
      Originally posted by rayz
      pics no werkie?
      They work fine for me.
      Originally posted by Gruelius
      • Spaz
        Crazy Canuck
        • 2276
        well the first one is a fuel pump....i don;t know if its the transfer pump or main pump...if you want what bmw calls them, give me part numbers :P
        Cam .W '91 325is
        Spaz's 1991 Alpine White???? S52 Build Thread...
        • BMW BMXER
          • 2325
          Doo hickeys?
          I don't think either are floats, maybe sensor perhaps?
          Sold it.
          • rs4pro3
            • 5808
            Upper one is a Transfer pump/level sender
            Lower one is just a level sender.
            What year cars are these off of? I could possibley use the upper one(maybe my car's fuel system is all screwed up and has the wrong parts on it.
            85 325e 2.7 ITB'd stroker
            • Jand3rson
              • 37587
              They are from an 89 325i.
              • rs4pro3
                • 5808
                Does it have an external Fuel pump also on the driver's side?
                • Jand3rson
                  • 37587
                  Would that one be down under the car, near where the fuel filter is?
                  Forgive me, I can't remember! :D
                  • rs4pro3
                    • 5808
                    Ya if it does that is the Main fuel pump and the pump pictured is the transfer pump
                    • James Crivellone
                      Head Janitor
                      • 6304
                      Don't 88's and newer only have 1 fuel pump?
                      • Jand3rson
                        • 37587
                        I think you're right James. I think the top pic is the fuel pump and lever sender, and the second one is just a lever sender.
                        • rs4pro3
                          • 5808
                          Ya they should that is what is messed up with my 88 as it has two level sending unit in the take and no internal pump Only one external Fuel pump the car runs fine once warmed but it takes it a while to build up fuel pressure(just noticed since Installing My ADJFPR)
                          • Beau B
                            • Mar 2004
                            • 734
                            89 don't have an external fuel pump, just the one in the tank, like James said
                            Beau
                            1988 BMW 325iS
