Why is tach bouncing?
  • grlaneriejr
    • 321
    Hey guys, a question.
    I just changed my plugs, cleaned my O2 sensor, cleaned my temp sensor, and adjusted my valves. Now my car runs much better.
    I have another problem, though. Now my tach is bouncing all over the place, also my MPG guage. Why is this doing this? It didn't before.
    Does anyone have any ideas?
  • MattE30
    • 1520
    Could be the SI batteries, or bad wiring, among other things. I suggest chaning the SI batteries first, and if that doesn't work, maybe replace the tach unit.
    97 Cosmos M3
    • grlaneriejr
      • 321
      I don't know. I let the car sit for about 3 hrs and now it's fine. weird, huh?
      • bimmerphile
        • 3495
        Loose ground on the back of the cluster?
        Broken wire in the SI board?
        Those are my guesses.
        • grlaneriejr
          • 321
          okay, i'll check both of those out next weekend.
          thanks
          • qimis
            • Mar 2004
            • 279
            mine started like that, it went crazy
            and couple days later, it died ....
            • McGyver
              • 4553
              i've been having that problem since i bought my car a year ago. i have the motrometer display and i thought that it would start to bounce to a higher rpm when it was hot cuz after it sat for a while it would be steady again. well i have been driving it everyday for the past month and no jumping and now i have the problem again today. when i rev it high it will seem to catch up and read acurate again until the rpms drop. i also had my ecometer bounce down and my mph bounce down for a few minutes one day. is this the problem you're having and did anything fix it?
