M20 swapped 318is Fuel problems
  • Axxe
    • Aug 2004
    • 3355
    So it appears that either fuel pump is dying. I have been having a hell of a time finding a used M42 fuel pump, and M20 fuel pumps don't work. Now, what I want to know, is if its possible to use the early m20 "booster" pump (that sits near the fuel filter) and wire it up parallel to the in tank (or seperate relay, doesn't matter really). Will there be any repercussions to this? I have two full early m20 pump setups, so I'd rather use what I have if I'm going to be hacking shit together. Remember that this is just a beater, so I want it to run and that's it.
    Keep it slideways!!
    Just buy a new pump...
    • Axxe
      • Aug 2004
      • 3355
      BEATER. Do you understand? BEATER.
      Go and price a new 318is fuel pump. Its almost $300 by the time I get it shipped. 325i pump is only $150 on the other hand. So yeah, I'm not dumping $300 into a $200 car....
      Keep it slideways!!
      • etxxz
        • Feb 2006
        • 2085
        no fuel. no beater.
        buy ebay pump for less than $80 and change just the pump, not the whole assembly
        No more e30s for me.
        88 black BMW OBDII 332is dedicated track [sold]
        88 BMW OBDII bronzit 332is [RIP 03/08]
        91 BMW 325i [sold]
        86 Corolla 'Ae86' HB 20v trd [sold]
        http://youtube.com/watch?v=pTj7Hn9v5Rs
        • Axxe
          • Aug 2004
          • 3355
          The car runs, it just starves for fuel occasionally.
          BTW, any experience with a $50 fuel pump? I'm thinking the external one will work better.
          Keep it slideways!!
          • Joe318is
            • Sep 2005
            • 6451
            When does it starve? I had this problem on a 318is and it turned out that the filter on the bottom of the pump assembly had fallen off into the tank. Under hard corners the intank pump would flop around and cause it to starve.
            Originally posted by vlad
            • Axxe
              • Aug 2004
              • 3355
              Straight line, usually AFTER doing some hard acceleration, but not necessarily. It's mostly random.
              Keep it slideways!!
              • Jordan
                • 12916
                Another option to consider is an aftermarket pump. You can buy just the actual pump, which comes with a new filter sock, and swap it out with your own into the existing assembly. All you need do is solder 2 wires. Its easy and I've done quite a few.
                https://mtechniqueabs.com/
                • Axxe
                  • Aug 2004
                  • 3355
                  Hmmm. Details on the process? I have a 325i late model pump, so I can swap the pump over. I was looking at the top cap, that seems like it compresses, but I did not want to break anything. What's the proper process for dismantling the pump?
                  Keep it slideways!!
