high beams only work on one side.
  • 2002maniac
    • 4260
    my low beams are working fine but when I turn on the high's my passenger side low beam turns off and the high doesnt come on. The result is both lights on the drivers side working but nothing on the pass side.
    where should I start in the troubleshooting process? how do you diagnose a bad relay?
    318is btw
    • 34844
    you have sealed beams right? it's burned out. replace with a new low beam.
    • 2002maniac
      • 4260
      H4 H1 Hella's
        • 34844
        same deal - H4s are dual filament. replace the bulb :p
        • 2002maniac
          • 4260
          no that's not it. I switched the bulbs left/right and the problem is the same.
          • kencopperwheat
            King of Kegstands
            • 14396
            Sounds like the relay.
            Originally posted by Gruelius
            • redhatpat
              • Aug 2005
              • 656
              Check your fuses? Left/right are on separate fuses for redundancy.
              • 2002maniac
                • 4260
                Fuses are fine. How do I test the relay?
                • backtrail69
                  • Jul 2005
                  • 4471
                  The relay only controls the high and low beam circuits, not each side individually. You sure you don't have the high and low beam connectors swapped? I did that once. Semi similar situation.
                  :: PNW Crew ::
                  '87 325 4dr, '74 2002
                  • 2002maniac
                    • 4260
                    hmm, pretty sure seeing as the connectors are different. Thanks for helping me rule out the relays.
                    • DaveSmed
                      • Apr 2007
                      • 1407
                      Swap fuses #1 and #2
                      -Dave
                      2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
                      Need some help figuring out the ETM?
                      • craig4ie
                        • Sep 2006
                        • 359
                        If I remember correctly, the horn relay is the same part # as the hi-lo relay. Pull the horn relay (assuming your horn works) and try it in the hi-lo location to see if it works...
                        1991 Diamantschwarz 318is
                        1998 Cosmosschwarz M3 Sedan
                        • golde30
                          • 11464
                          i have this same thing with my 318is, but reversed. im pretty sure mine is the lamp, as there is water inside. lol
                          IG: @Baye30
                          • buhnahnuh
                            • Nov 2007
                            • 69
                            I had my left front turn park and head light go out, it was a fuse
                            • kowalski
                              • Jan 2005
                              • 1791
                              change the fuse regardless. how does the connector look on the burned out side?
