How do you get these muffler hangers (donuts) on??
  • M5wanaB
    • Aug 2007
    • 405
    Ive been trying to put the exhaust back on my car but it got dark so I had to call it a day. I am wondering what is the proper way of putting the rubber donut exhaust hangers on?? I cant even get the thing stretched over 1 of the sides of the mount let alone both. I am thinking of trimming them up with the old angel grinder but would like that to be the last resort. any help would be appreciated.
    1991 325iC w/ 75k Original Miles, Brillantrot, 5-speed, 16" BBS RX's, Black Leather Sport Heated Seats, LSD, and Diving Boards for life!!!:D
  • ///M42 sport
    • 3952
    You just gotta put some muscle into it...Use a something so that you can twist the donut onto the hangers, I used a paint roller. Thats the only way to get enough leverage to stretch the rubber.
    • M5wanaB
      • Aug 2007
      • 405
      twist it on?? like put it on so its 90 degrees off then twist it into place??
      • NC325iC
        • Mar 2004
        • 6565
        i had to use some big ass channel locks if i remember correctly
        • M5wanaB
          • Aug 2007
          • 405
          damn, im fresh out of big ass channel locks. might have to make a run down to harbor freight. any other tools that are useful? so far we have
          "a paint roller" & "big ass channel locks" let me know.
          • bimmer8604
            • 3017
            lube 'em up. silicone spray helps.
            1988 M3, 97 840, 99 XJ
            DILLIGAF
            • M5wanaB
              • Aug 2007
              • 405
              im getting there but damn these things are a bear. Wish I knew these things were this hard before I put the muffler in. I would have removed the straps and got these out of the way before putting the muffler in. oh well it will just take more time, just wish I had more of it.
              • SchnellerVert
                • Sep 2005
                • 3948
                bend a tab slide it on, bend the tab back straight. Easy.
                • M5wanaB
                  • Aug 2007
                  • 405
                  so simple. cant believe I didnt think of it. Good Idea. Sounds a little better than my Idea of using the angel grinder to remove one of the tabs. Probably wont get to tackle this again till tuesday but thanks for the help guys and if anyone else has any good info like this, keep it coming. thanks again.
                  • whowhatwhere
                    • Aug 2007
                    • 259
                    Put it on the chassis first, then rotate the hangar into the rubber donut. I did it without swearing once.
                    • SchnellerVert
                      • Sep 2005
                      • 3948
                      Think out of the box sometimes, try not to over think the issue.
                      • M5wanaB
                        • Aug 2007
                        • 405
                        but did you already have the muffler in place?? either way I think I will be able to get it from here, just wish there was more room to work with, the muffler is so big and bulky its kinda hard to work around, and I had to remove the heat shield with it still on the car. that was really fun. Actually the heat shield is still in there, I cant get it all the way out ive just been sliding it around so I can work on one side at a time. live and learn. I really wish I had the bently for this car Im sure it would have saved me a headache on this job. I got a chilton manual that came with the car that covers 89-98, its worthless. most of the time I feel more stupid after reading it than before. thanks for a nother good suggestion.
                          • 37833
                          Some dish soap and a prybar. Bending a tab over and over is not a good thing.
                          Grover Beach, California
                          BimmerHeads.com
                          • SchnellerVert
                            • Sep 2005
                            • 3948
                            Mild steel won't break Matt, it's not like you are bending it a bunch of times getting it hot that it break.
                            • AndrewBird
                              The Mad Scientist
                              • 11898
                              Yes, they can be a bitch. I've just pried them on before with a big screwdriver. Hook it on the car first, then hook the muffler to it.
