what kind of clutch?
  • backlife
    • 104
    i need to get a new clutch when i rebuild my tranny what is a good clutch to buy fairly cheap.
    -adam
  • Jordan
    • 12912
    OEM Sachs.
    https://mtechniqueabs.com/
    • AdamF 88iS
      • 2051
      Stock OE Sachs clutch. If you have a lot of power you can move up to an E30 M3 clutch, but stock is what you need. They last forever if you don't abuse them.
      Adam Fogg- '88 M3
      Common sense- It's the new 'gifted'
      • decay
        • 5637
        M3 clutch sounded like a good upgrade at first- but it's $325 for the sachs kit through alloemparts. for that much i'll just spring the extra bit for the spec stage3, unless anyone knows of a cheaper source...
        past:
        1989 325is (learner shitbox)
        1986 325e (turbo dorito)
        1991 318ic (5-lug ITB)
        1985 323i baur
        current:
        • Sean
          • 5793
          A clutch kit at Pelican Parts ran around 270-280 or so - and that came with lots of the seals and stuff that may need replacing.
          Try them out - pelicanparts.com
          But, if you consider the SPEC Clutch - I'm still trying to get this group buy back on the road, http://www.r3vlimited.com/phpBB2/viewtopic.php?t=6560.
          I sent him an e-mail, hopefully there's still a possibility to get the group buy.
          - Sean Hayes
