How much air in 205/50/16 tyres ?
  • mjc85
    • Mar 2004
    • 164
    Hey i need to pump my tyres, getting a bit flat, it doesn't say on the tires what pressure to use. What pressure should i use for 205/50/16's ? Do i put different in front and rear ?
    1990 318is Brilliantrot
  • tobybmw
    • 453
    I run 33 front and rear on the street.
    Andy
    • mjc85
      • Mar 2004
      • 164
      is that PSI (pounds per square inch) ?
      • NC325iC
        • Mar 2004
        • 6565
        yea
        • Sean
          • 5793
          I usually run a bit higher than 33 - I do around 36-37 up front, and 34-35 in the rear. For most road driving, it's usually 36 front and 35 rear.
          33 seems kind of low, but since I have tires on 14" rims, I want to make as little sidewall movement as possible. ;)
          - Sean Hayes
          • James Crivellone
            Head Janitor
            • 6304
            I run around 36 on all 4
            • E30godz
              • 1524
              im runnin about 36 up front and 40 in the rear.....god i love oversteer.
              • sovann
                • Jan 2004
                • 292
                I run 32-34psi cold front and back in my 205/50/16s. Gets up to around 38psi when warmed up.
                • Digitalwave
                  is a poseur
                  • 6287
                  That setup is more prone to understeer. Switch to 40 in the front and 36 in the rear, and you should have more oversteer.
                  I run 35psi cold for the street with the same tire size.
                  RISING EDGE
