HELP with Fuel Pump Hard-Wire (PIC inside)...
  • TurboMeTroy
    • Nov 2004
    • 184
    There are two harnesses that go to the top of the Fuel Pump -- one with 2 wires (12 o'clock in pic) and one with 3 wires (disconnected in pic)...I tried hard wiring the 3-wired harness directly to the battery to see if it would turn on...started smoking and no sound -- I'm guessing that's the relay-connected harness?
    Any ideas? Help?
    Thanks in advance!
    te
  • TurboMeTroy
    • Nov 2004
    • 184
    Can someone shed some light on this...I'm running out of daylight here in Minneapolis...
      The loose connector in the picture is for the level sensor. The smaller two wire connector that's still plugged in is for the fuel pump.
      • TurboMeTroy
        • Nov 2004
        • 184
        So the 2-wired harness is for the pump...there is a red wire and a green wire...neither is getting 12v continuous or with aCC on... which one is ground?
        • NC325iC
          • Mar 2004
          • 6565
          two wires is for the pump, if you hook it up backerds itll run the pump backerds
          • TurboMeTroy
            • Nov 2004
            • 184
            K...ran a wire directly to the battery...so it's obviously hot...grounded it (with a multi-tester) on each of the two wires in the FP harness...and BOTH acted as grounds, generating 12v + ...now how in the hell is one them not a ground? $%!$!@$@#!
            • TurboMeTroy
              • Nov 2004
              • 184
              • TurboMeTroy
                • Nov 2004
                • 184
                Anyone....
                • DaveSmed
                  • Apr 2007
                  • 1407
                  You have just succeeded in making your fuel level sender extremely unhappy. May as well remove the four nuts holding it in and chuck it and go get a new one now.
                  What in the hell are you trying to do besides break stuff/engulf your car in flame if you don't mind me asking? WHY would anyone want to hotwire a transfer pump is beyond me.
                  BTW the pumps only run when the engine is turning= cranking or running.
                  -Dave
                  2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
                  Need some help figuring out the ETM?
                  • Rocla
                    • 922
                    Brown should be ground and green/violet should be the +12 from fuse 11.
                    Current:
                    BMW 320i 2d 2.0 m20 -88
                    BMW 325i Cabriolet 2.5 m50 -88
                    BMW 316i touring 1.6 m40 -90
                    BMW 320i 4d 2,2 m54 -01
                    • Disaster Inc
                      • Oct 2007
                      • 429
                      Does it matter if the two wires are reversed on the pump? The original plug was hacked on mine, it works/runs now. I'd go outside to look which is on which side but its fuckin cold.
                      • NC325iC
                        • Mar 2004
                        • 6565
                        look to my post
                        • Disaster Inc
                          • Oct 2007
                          • 429
                          Originally posted by NC325iC
                          look to my post
                          Your post is what got me thinking about it... so my question I guess is which wire to which side is correct?
                          • TurboMeTroy
                            • Nov 2004
                            • 184
                            Well Dave - No, I wasn't trying to break stuff or engulf my car in a single flame. .
                            And I just love wiring transfer pumps, it's an ol' past time of mine.
                            • DaveSmed
                              • Apr 2007
                              • 1407
                              Ok, thought it was an odd hobby. What is your car doing/not doing/sometimes doing/sometimes not doing/doing on Wednesdays that your trying to change?
                              -Dave
