Car takes a few more cranks than usual to start.
  • rwh11385
    lance_entities
    • 18403
    Simple problem, when I turn the key it takes several more cranks to get the engine started. Sometimes I need to stop and retry the key, occasionally mutlitple times.
    I would IM someone, but all you fools are asleep at 2AM. Weird.
    Hmmm, if think the similar thing happened when my G20 battery was dying down, but there's been nothing to run down the battery.....hmmm
    Battery? Starter? what.....
  • Spaz
    Crazy Canuck
    • 2276
    hey u can catch me on aim
    wishiwazboarding
    Cam .W '91 325is
    Spaz's 1991 Alpine White???? S52 Build Thread...
    • James Crivellone
      Head Janitor
      • 6305
      mine does that sometimes, i determined it was low fuel pressure that is teh cause, I have not really gone into fixing it though, does not annoy me enough :p
      • Spaz
        Crazy Canuck
        • 2276
        thats what i'm saying too. happens to my car some times also.
        Cam .W '91 325is
        • jweb
          • 959
          Happens to me all the time too. It seems my car actually starts better in cold weather. However, if I have driven the car within the past hour it will start on the first crank.
          Btw, aim isn't connecting for me.
          Jamie Webster
          '89 325is - sold :(
          '96 Miata - sold
          '01 M5 - sold
          '02 Civic Si
          • 808BMW
            • 2910
            My car does that, it will start up easy if you haven't driven it for a while (all night) or if you just drove it (less than 1 hour) but anything between that will just keep cranking and cranking...
            I remember hearing discussions about this, I think it went down to some hard to reach fuel lines or something.
            If anyone figure it out, tell me cause I wanna fix this too.
            • Wes325
              • 563
              most likely it's either your alternator or your fuel filter. Good news is that you can replace these yourself with some a little bit of skill and the fuel filter is cheap. Bad news is if its your alternator then that equals $$$$. Do a starter draw test on your alternator. Also check your fuel pressure. I think the M20 is 42psi?????
              ________
              TX300
              - 318is 4 life
              • 808BMW
                • 2910
                I remember my fuel pressure was low, but my fuel filter is new.
                Alternator is fine.
                • Wes325
                  • 563
                  Alternator is fine.
                  That helps narrow it down, depending on the mileage of your car and the gas you run it could be your fuel pump. It usually goes out around 125K.
                  ________
                  vaporizer wholesaler
                  - 318is 4 life
                  • 808BMW
                    • 2910
                    Alternator is fine.
                    new pump too
                    I've already gone into this problem and tried to figure it out (a couple times), ended up with new parts, no money, and same problem.
                    • e30evolution
                      West Werks
                      • 1888
                      you just put in bigger injectors right? mine take longer to crank now too with the bigger injectors
                      http://www.westwerksauto.com
                      • bimmerphile
                        • 3495
                        OH SHIT DUDE
                        I heard that happens when they wire a car bomb up to your alternator
                        j00 @43 fUx043d!!!!!!1111one
                        • NC325iC
                          • Mar 2004
                          • 6565
                          same here
                          • bimmerphile
                            • 3495
                            same here
                            I'm on AIM, let me get off and see if I can reconnect (something tells me I'll regret this)
                            Nope, works fine for me.
                            • 808BMW
                              • 2910
                              WRONG!
                              Here's the correct way:
                              j00 @43 fUx043d!!!!!!1111oneunoeinumодно
