Car takes a few more cranks than usual to start.
    Originally posted by Wes325
    Originally posted by 808BMW
    I remember my fuel pressure was low, but my fuel filter is new.
    Alternator is fine.
    That helps narrow it down, depending on the mileage of your car and the gas you run it could be your fuel pump. It usually goes out around 125K.
    Well, I have 124K miles......
    I'll note fuel filter, fuel pump, alternator.
      own3d.
        So, before we go and tear up all the fuel system in the car, how's the battery?
        -Charlie
        Swing wild, brake later, don't apologize.
        '89 324d, '76 02, '98 318ti, '03 Z4, '07 MCS, '07 F800s - Bonafide BMW elitist prick.
        FYYFF
          C, I'm not tearing anything apart, just making a list of possible causes. Oh yeah, forgot battery for a sec.
            fuel injectors
            http://www.westwerksauto.com
              i think they are the injectors, same thing happened to me.
                If it's the injectors, pour a can of Sea Foam into your gas tank when it's nearing empty. It should clean them out well.
                  well, it might have been the injectors, because I did do that recently. But then again, the problem seems to have gone away, or at least reduced itself to where I don't notice as much.
                  I think another can of sea foam might not be a bad idea.
                  I need to replace my battery anyway too, it's from a modern 5 series and the hookups are on the wrong side. (previous owner) and the battery tray is gone. I need to have it tied down properly before I can participate in a DE. (as well as other things......)
                  After that, maybe fuel filter, just because.
                  If still an issue, check alternator, fuel pump.
                    check the sealing between FPR and the fuel rail
                    a friend of me his car has this problem
                    his car needs a few more cranks too after a night
                    1989 E30 318iS_______________________________1989 E30 325iC M-Technic I
                    1997 E36 328iT
                    1990 E30 325iT 24v SOLD
                    1989 E30 325i 2.7i M-Technic II SOLD
                      For larger injectors it's normal, mine does samething too.
                      Replaced fuel filter other day and it got better, but best way to check if it has anything to do with fuel is, turn key on, do it twice for couple of seconds and fire it up. If it starts right up than you know what's the problem, it's something with fuel if it still takes long, then it could be your battery.
                      Check your altenator output, it should be putting out new 14Vs, if it's below 13V than your alternator might be going.
                      95' M3.
                      90' 325i Turboed.
                      87' 325eS Fixed.
