How does this hose clamp work?
  • funcrew
    • Jun 2007
    • 1223
    So I'm doing the timing belt and all the stuff that's recommended while I'm in there. Every last little thing on my new E30 is completely different from the Fords and Chevys I've been messing around with all my life, and I'm not smart enough to "just know" by looking at it.
    So, how does this hose clamp work? (radiator overflow line)
    "If the sky were to fall tomorrow, the tall would die first."
    -Dr. Paul Forrester
    Do I LOOK like I need a psychological evaluation???
  • dkmr
    • Jan 2006
    • 332
    looks like a one time clamp. from my experience when you actually get it removed you get a new one and the crimper for it, or you put on a regular band clamp.
    • funcrew
      • Jun 2007
      • 1223
      Thanks - I'll grab a normal clamp for it.
      -Dr. Paul Forrester
      • lordofthewaters
        • Oct 2005
        • 714
        In my experience you'll wanna keep spares. And try to avoid the cheap HW store clamps if you can.
        Sarcasm is a body's natural defense against stupid.
        When a man talks dirty to a woman, it's sexual harassment. When a woman talks dirty to a man, it's £3.95 per minute.
        "My mother never saw the irony in calling me a son-of-a-bitch." Jack Nicholson"
        Old age and treachery will always overcome youth and skill.
        • 1991 318is
          • Dec 2005
          • 786
          They're called Oetiker Clamps. They use a special crimping plier. Also used on CV joint boots and where there are clearance and rotational weight problems. Small sizes are available from a Sea-Doo dealer and online at: http://www.racerpartswholesale.com/c...Oetiker_Clamps
          • viali8
            • Nov 2005
            • 673
            i took mine off (when i did my timing belt) and used a regular hose clamp and i have had no problems with it
            • der affe
              Technical
              • Dec 2005
              • 8452
              just make sure the clamps you put on are the "german type". if you look at the edges of the clamps they are angled up a little bit so when you tighten them down they don't cut into the hose like the "american type" you will find at most check/autozone/pep boys/craigen. try to find a parts store that specializes in import cars to get them from.
              • viali8
                • Nov 2005
                • 673
                clamp
                good to know. i never realized that
                • Jparkr
                  HR Admin
                  • Jan 2006
                  • 3494
                  They are reusable, use a screwdriver and twist the crimped area apart. Then when you reinstall use the tool ($55 from snap-on/Mac/ect.) or use dikes (cheap)
                  1987 PRO-3 car /1990 325is (2.7i Concours)
                  • funcrew
                    • Jun 2007
                    • 1223
                    Good info, but $55 will buy a lot of new hose clamps! :(
                    -Dr. Paul Forrester
                    • AlarmedBread
                      • Sep 2006
                      • 1510
                      Get one of these at a pawnshop for $1 and file down the edges so it won't cut the clamps.
                      • ethree
                        • Aug 2007
                        • 1216
                        Call me cheap, call it r3v whatever, but I get all my hose clamps from the junkyard. Audi, volvo, saab they all use good hoseclamps and you can get as many as will fit in your pocket in various sizes for a nominal $2 entry fee. Just clean them with a little wd and they're as good as new.
                        • el bob
                          • Feb 2006
                          • 348
                          I might go the modified cutoff tool route posted above, but I was curious to see the tool in the Snap On catalog but I could not find it. Do you know the part number?
