Changing my oil filter and had a question??
  • ian e30 318is
    • Mar 2007
    • 1809
    I just put in my oil filter and I was wondering if it was neccessary to change the seals. i know the filter came with two black seals (one big, one small) and two washers. I know the big one goes around the top but where does the small one go and also the washers? never changed my oil filter in the bmw. thanks.
    Ian
    1991 LS1 Swapped 318is
    Instagram:
    https://instagram.com/saltybeast/
    LS Build Thread:
    https://www.r3vlimited.com/board/for...s-e30-ls1-swap
  • brandondan1
    • 1091
    Don't know about the extra seal. I just use the one that goes around the circumference of the filter. Use the new crush washer on the oil drain plug.
    91 318is
    • craig4ie
      • Sep 2006
      • 359
      Yeah, the crush washer replaces the one on the oilpan drain plug and the other washer goes on the bolt you have to undo to get the oil filter out.
      The small (1/4" diameter rubber seal) goes in the groove at the end of the bolt for the oil filter.
      1991 Diamantschwarz 318is
      1998 Cosmosschwarz M3 Sedan
      • brandondan1
        • 1091
        Are the filters on m42s in the engine bay? My bro used to have one, but I don't quite remember. Sorry, was thinkin about m20
        91 318is
        • ian e30 318is
          • Mar 2007
          • 1809
          Yeah they are located pretty conveniently actually. thanks for the help.
          Instagram:
          LS Build Thread:
