Welding question
  • kroberts
    • 680
    Welding question
    I have a new Stromung muffler and I need to modify a small support strap across the back of the pipes on it. The part is stainless steel. I have a 120v Hobart mig. I know this is probably an elementary question for trained welders however I am not one. Can I use general purpose wire for a small weld on SS? The part is about 1/8" thick and I have access to all sides.
    Thanks
  • hoveringuy
    • Dec 2005
    • 2752
    I used my Lincoln 110 mig on the OBDII stainless header without any problems. No gas, shielded wire. A little more spatter than mild steel but still a good weld. You should have not problem unless it's much different alloy than the stainless on the OBDII headers.
    • whowhatwhere
      • Aug 2007
      • 259
      Go for it, it wont pass an aerospace test, but it will hold fine for a muffler hanger.
      • kroberts
        • 680
        Thanks lads!
