Anyone know what this part is
  • Court M3
    • Jan 2004
    • 6713
    Think this might be causing the high idle condition in the car. 4 hoses running into it.
    2 coolant in-out
    2 air manifold in-out
    Went to look for one, but after looking over a few early cars in yards came to the conclusion they are not on US cars
    Continuous For Sale Thread
    323i s50
  • AndrewBird
    The Mad Scientist
    • 11892
    Where is it located?
    • Court M3
      • Jan 2004
      • 6713
      right under the manifold.
      323i s50
      • Court M3
        • Jan 2004
        • 6713
        checked RealOEM for over an hour and could not find it. Maybe one of the Euro guys can chime in?
        323i s50
        • SchnellerVert
          • Sep 2005
          • 3948
          Early style warm up regulator is what it appears to be. Additional air slide valve. Sounds like that is hung up hence the high idle. Maybe it's frozen with moisture in it?
          • DaveSmed
            • Apr 2007
            • 1406
            Oh wow, one of those things.... Old school ICV. Works similar to a coolant thermostat.
            Coolant hoses getting nice and hot?
            -Dave
            2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
            Need some help figuring out the ETM?
            • Court M3
              • Jan 2004
              • 6713
              coolant hoses are nice and warm. Now to find a part number for the damn thing!
              323i s50
              • SchnellerVert
                • Sep 2005
                • 3948
                It's listed on realoem as mentioned.
                • Stevie30
                  • Apr 2007
                  • 1534
                  2 coolant in-out
                  11531287304 Additional Air Slide Valve (realoem.com)
                  1991 325ic and 1991 318is
                  • Court M3
                    • Jan 2004
                    • 6713
                    Thanks! Must be a tard
                    323i s50
                    • Court M3
                      • Jan 2004
                      • 6713
                      checked around and the cheapest this part can be had is $173 plus shipping OUCH! Found a couple of hoses that had coolant/water leaking. Might be the prob. Looking at it, I'm thinking it might be able to be bypassed. What do you guys think?
                      323i s50
                      • DaveSmed
                        • Apr 2007
                        • 1406
                        Well, kinda. I've bypassed them before (non-BMW) but the car in question needed to be manually kept at a high idle for a minute or two for the first start of the day. You bypass (well, plug off) the air, not the coolant. If you simply bypass the coolant, it thinks its cold all of the time and it idles high all of the time.
                        -Dave
                        • Court M3
                          • Jan 2004
                          • 6713
                          will remove and clean it out this afternoon. Couple people on bimmersport.co.nz suggested it.
                          323i s50
                          • Court M3
                            • Jan 2004
                            • 6713
                            Dave air part works fine. Opens as temp rises and closes as it cools down(according to the kids on bimmersport). Coolant pipes should be a straight through feed right? Mine are blocked with some type of crud :(
                            323i s50
                            • Elephant
                              Site Sponsor
                              • Jan 2008
                              • 328
                              Ouch indeed, that's BMW NA retail pricing. You should be able to get it fro 20% off if you really do need it, at least I can offer it to you for that.
                              Good luck, hopefully you can dump the thing!
                              Cheers.
                              Jack Money
                              http://www.Elephant Motorsports.com
                              >> AST 4100 for BMW E30 $1649 <<
                              AST Monotube Dampers and Coilover Kits - Full Service Dealer
                              Schroth Safety Products Distributor
                              BMW Replacement Parts - 24/7 Secure Online Ordering
