Hi all.
I have a sunroof problem.
The motor works. But the roof won't move. I removed the access door and saw that the motor was loose. If I hold the motor in a certain place, I can get the roof to move up and down (not very well... it seems one side goes higher than the other).
I removed all the screws and check panel from the headliner panel, and was able to move the panel down a few inches. That enabled me to see a loose Phillips screw which I tightened. The motor is tight now, but when it turns, the gear just clicks.
I want to remove the headliner panel, and I know that the sunroof has to be partially open to do this. How do you get the motor to change from raise/lower to slide in/out?
Thanks.
Thanks.
