ABS Removal
  • Dyno4mance
    • 345
    ABS Removal
    Hi Guys....I am a new member and I am currently building a dedicated track car and I wonder if anyone has any info on removing the anti lock braking system from the body shell of a 318is.... what master cylinder and pipe routing is used...
    I have searched for a while now on this site, M42club, e30tech and more but to no avail
    any help would be much appreciated...
    Andrew
    2.7L M20 11:1 COMP 195 whp Dyno Dynamics 2380lbs
  • Jean
    • 18228
    The early 325s had the non abs MC, along with the early 318s.
    • Dyno4mance
      • 345
      Thanks for the fast reply....I wonder if the earlier cars used girling up front and it would be a no brain swap?
      What year 325s are you talking about 1987 or earlier?
      • DaveSmed
        • Apr 2007
        • 1407
        So many revisions throughout the years.... Early in this case refers to '84-'85 only.
        -Dave
        2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
        Need some help figuring out the ETM?
        • ethree
          • Aug 2007
          • 1213
          Is there a lot of pipe bending and fabrication involved in swapping the mc's? or do the non-abs mc's just have fewer connections which are used by the non-abs lines allowing the lines and abs brain to be easily disconnected and removed?
          • StereoInstaller1
            GAS
            • 22679
            Have you actually been able to trigger the ABS? I have only made mine trigger once in 50,000 miles of spirited driving...nothing like racetrack use, of course...but it has to be the least obtrusive ABS I have ever heard of.
            Closing SOON!
            Thanks for 10 years of fun!
            • ethree
              • Aug 2007
              • 1213
              I want the space that the "brain" takes up in the corner of the engine compartment, but yeah Ive only had the abs engage once as well.
