Electric fan replacement for the stock fan? What to use?
  • george graves
    • 19998
    Any one recomend a brand/model of electric fan to use when deleting the stock fan?
    Originally posted by Matt-B
  • rs4pro3
    • 5808
    I also want to know, I wired the aux fan to a switch on my 318i and it's held up fine for a year but the wiring hasn't held up as well(melts 30 amp fuses monthly) I think the fan just wants to much power.
    85 325e 2.7 ITB'd stroker
    • e30Matt
      • 5077
      If you're not running A/C, just cut the belt to the A/C compressor and use that switch to cut it on/off. Your engine will idle up slightly when you turn it on, but it's nothing major. I'm trying to figure out how to disable that.
      • rs4pro3
        • 5808
        unplug the wire where it plugs into the ecu. it's not in the flat three row conector for the obc code function but in the other 2 connector plug.
        • Rob
          • 8166
          ely, wanna walk me through hard wiring the aux fan? 8)
          BEERTECH
          • e30Matt
            • 5077
            Isn't it already done in the parts car?
            • rs4pro3
              • 5808
              I wired it completly seperat from anything. I pulled the fan/condensor assembly out.
              -removed the fan resistor, wires some 12 guage wire directly to the fan and ran it to a relay with it's own fuse power source right off the battery, I then ran another fuse off the battery and ran it to a lighted switch I installed on the E-break consule, So the switch kicks on the relay and the relay powers the fan. At first I wired the fan right off the switch but melted a switch. And like I said for some reason the fuse for the relay blows every month or after using the fan 20 times or so. I still have the fan clutch on but my m10 likes to heat up at traffic lights so once the temp hits half way I flick the switch and the fan cools the engine back down nice and quick.
              • rs4pro3
                • 5808
                I think the stock aux fan wired to the temp switches on the radiator would cool the engine plenty enough. That's my plan unless I find a cheap enough electric fan on ebay. Auto zone has plenty of fans for Hotrods I took a look at that are decently priced.
                • Rob
                  • 8166
                  yeah you're right matt....i may steal some more shit off that. If not, I'll try Ely's method. My aux fan never comes on, gotta figure that one out, might as well get some more cooling in the process
                  If I didnt already have 2 fans, I'd look into the SPAL or FAL (something like that) fans that the hot rod catalogs sell.
                  BEERTECH
                  • E30godz
                    • 1524
                    yea i have two aux fans too, and wouldnt mind dropping the engine fan for an electric swap
                    • rs4pro3
                      • 5808
                      If any one is interested I may make some mounts to mount the aux fan with out the ac condensor core. I've been meaning to install the aux fan back in my 88 325is without the core and tommorow would be a good day. So I'll make some mounts out of some sheet aluminum I have.
                      • rs4pro3
                        • 5808
                        http://cgi.ebay.com/ebaymotors/ws/eB...906685728&rd=1
                        Probally something like that would work good George. I'd just find out what the stock CFM output is and go equal or higher with the electric fan.[/url]
                        • rs4pro3
                          • 5808
                          Here is a thread from mye28 about some electric fan conversions
                          • e30evolution
                            West Werks
                            • 1888
                            i dont think that will work so easily... this is what i am going to do, but the fan only turns on in certain conditions.... the the condensor temp is too high and maybe if the coolant is as well... but i wouldnt remove my other fan and trust that electric one, i would want a much more powerfull fan before i remove my stock fan
                            http://www.westwerksauto.com
                            • e30Matt
                              • 5077
                              I'm running without my engine fan in 90 degree heat, using just the aux fan. The needle has yet to reach the center mark... I'm still running 50/50 coolant/water too, I'm flushing it this weekend to run 100% water + Water Wetter.
