Veggie oil 324Td
  • atomic
    • Jun 2007
    • 5691
    Originally posted by mrsleeve
    Atomic,
    the 1st 400 gal or so per quarter for personal use is exempt form the 32 cents a gallon road use tax (most states have flowled suit) any thing over that you must settle up on at the end of the year. Now for business use you may not be exempt an will owe 32 cent on the gallon for every gallon used plus you state taxes on the fuel too. But you would have to look into the business use and the exemption status of that.
    Hey thats good to know. If I go this route I will check everything out before taking the plunge for sure. Also might just have to buy a tractor and bobcat to get around the fuel for road use tax. :D ;) As the 400 gal per 1/4 will but tight to operate on both equipment and truck.
    • mrsleeve
      • Mar 2005
      • 16390
      yes for the off road you can use the Red fuel. So my if I were you just use all home brew cept when its really cold out. Just keep track of what you put in the truck. Just so long as its less than 400 Gal per quarter you should be golden unless business are not in that rule. I spent hours on the Fed's tax site trying to find out if you have to pay the use tax on the home brew and SVO. Personal I know is not a issue, for business I cant say for sure. just run it I would guess its not an issue.
      Originally posted by Fusion
      William Pitt-
