The "The engineer was drunk, stupid bolt location" thread
  • browntown
    • Jun 2004
    • 3524
    Figured maybe we could put all the frequently bitched about fasteners in one place, and your best solution to get it.
    My short list:
    Exhaust manifold _> downpipe nuts (6-14mm copper nuts): Impact gun from below with a mishmash of extensions and a universal joint + lots of PB Blaster overnight. Once you inevitably round a nut, then you get to break in the fancy set of "bolt-outs" Might want to replace with copper greased torx head bolts
    Bitch clip: Best method here: http://www.unofficialbmw.com/e36/dri...itch_clip.html
    Might be a good idea to replace with a bolt
    Subframe brake lines. Don't bother, drop the subframe
    Separating the transmission from the engine in the car, good luck, best to yank the two out as a pair.
    Top bolt clutch slave cylinder: Undo the tranny subframe support, and lower the tranny an inch or two. Put a bunch a long wobble extension together and attack from further back on the tranny.
    There's got to be plenty of others, just the few that come to mind, please add.
  • jrobie79
    • Mar 2006
    • 2525
    oh yeah that bitch clip was a real winner, took me forever to get that bastard out, i could do it in my sleep now, still replaced it with a bolt tho
    1991 318i ---- 308K - retired
    • So Live
      • 2512
      Starter bolts in car with a M50.
      Guess that wasnt the engineers problem though...
      Brake booster to firewall kinda sucks too. really really difficult to get all the nuts on.
      Bitch clips sucks. I did mine out of the car and it wasnt so bad :)
      -Chris
      • AndrewBird
        The Mad Scientist
        • 11898
        This one is doable rather easily if you have the car on a lift. Without a lift, I can see it being hard.
        The one thing that might make this hard is if the tranny has never been out before. Stuck bolts would be a bitch, considering their location. Otherwise, completely doable.
        If all you need to do is swap the tranny, you don't have to pull the engine, but if you are doing something like the clutch or are going to have the engine out anyway, pull it as one.
        • AndrewBird
          The Mad Scientist
          • 11898
          I'll also add to the list:
          Fan clutch nut. A crescent wrench works or some have had luck finding a table saw wrench that is the same size. The advantage of this is the fact that it is slim. Another option is the tool made for this job. To keep the pulley from turning, either try wedging the alternator belt or buy the tool made for it. A LARGE pair of channel lock pliers around the water pump pulley will also work, but could/will scratch the paint on it.
          • Borat
            • Jan 2005
            • 494
            Does it matter if I was the drunk engineer?
            My lower exhaust manifold nuts are an absolute bitch to remove, gotta use an open ended spanner and slide it up between the block and tubing. 20/20 hindsight eh?
            • Tangent
              • Mar 2004
              • 476
              The sure as hell didn't improve the bitch clip on following models. About 75% of the time it took to install the Evo3 shifter in my 330i was getting that $%^&* bitch clip out.
              That godforsaken spring loaded jack-in-the-box pipe that connects the intake manifold to the oil pan on M20s can blow me.
              • NC325iC
                • Mar 2004
                • 6565
                ive gotten really good at the downpipe bolts, dont even have to use a u joint any more
                the control arm central ball joint is a pain in the ass
                • tjts1
                  • May 2007
                  • 1851
                  Not a bolt but still stupid. The M42 tb heater/crankcase ventilation heater/idle control heater. WTF were they smoking?
                  All replaced with one 8" hose.
                  • SamE30e
                    • Sep 2007
                    • 4319
                    Transmission, very top bolt..
                    4 extensions, 2 swivels, and a torx socket and about an hour of your time. Oh and infant hands would help too.
                    1985 325e 2.8 Turbo VEMS
                    • NC325iC
                      • Mar 2004
                      • 6565
                      that top tranny bolt is a bitch the first time around
                      2.5-3 feet of extensions rear support unbolted and hanging as fas as i dared let it and small arms and hands and a 2ft breaker bar
                      • xLibelle
                        • Aug 2004
                        • 2673
                        true to a T
                        • Elephant
                          Site Sponsor
                          • Jan 2008
                          • 328
                          I thought the fan clutch nut solution was known to everyone, including those who don't own E30's. I bought a 32mm wrench from HD or Lowes, wherever, don't matter, and ground it down to make it slim. Place wrench on nut, hit with heavy shot filled mallet. If this doesn't work then you're doing something wrong, I've never ever once been denied. Some are more difficult that others no doubt but a few good whacks and it's loose. This solution is the equivalent of a $5 whore, guaranteed. Heck I don't think I've ever even PB'd it beforehand (that would be the lube in this analogy).
                          Cheers.
                          Jack Money
                          http://www.Elephant Motorsports.com
                          >> AST 4100 for BMW E30 $1649 <<
                          AST Monotube Dampers and Coilover Kits - Full Service Dealer
                          Schroth Safety Products Distributor
                          BMW Replacement Parts - 24/7 Secure Online Ordering
                          • rede30
                            • 4697
                            The first three on your list i have down, still no fun though. I always dread the right front control arm because of that middle 19mm bolt. I have a technique but it still takes quite some time. I need a ratcheting 19mm wrench to end my pain.
                            • e30_kid89
                              • Apr 2006
                              • 489
                              ^^^Yep...that bolt made me cry. A bent wrench helped though.
