The "The engineer was drunk, stupid bolt location" thread
    Originally posted by Tangent View Post
    That godforsaken spring loaded jack-in-the-box pipe that connects the intake manifold to the oil pan on M20s can blow me.
    Ah yes, the spring loaded tube-o-death.
    Originally posted by Elephant View Post
    I thought the fan clutch nut solution was known to everyone, including those who don't own E30's. I bought a 32mm wrench from HD or Lowes, wherever, don't matter, and ground it down to make it slim. Place wrench on nut, hit with heavy shot filled mallet. If this doesn't work then you're doing something wrong, I've never ever once been denied. Some are more difficult that others no doubt but a few good whacks and it's loose. This solution is the equivalent of a $5 whore, guaranteed. Heck I don't think I've ever even PB'd it beforehand (that would be the lube in this analogy).
    Cheers.
    Josh and I had one that was stuck and then some. I think we ended up destroying the watter pump pulley it was on so tight. But yes, your method will work as well generally.
      Engineer was drunk when they designed the M20's oil pan. Worst designed part on the E30, period.
      "Vee shall dezign zee most crucial part of zee engine to be zee lowezt part of zee car. Und not only zat, vee vill alzo make zee pan out of zee most brittle metal vee kan find."
        I take it you have cracked your pan?
        I am in the middle of dropping my tranny and I just have the top bolts to get too and I am about ready to call around and see how much a shop would charge to finish this off, because my hands and forearms are exhausted.
        http://www.cardomain.com/ride/657387
          Nope, didn't crack it. Yet.
          And a shop isn't going to want to finish a job you already started and can't finish. If they do, they're going to rape you.
            wiper assembly install
            that shit is a puzzle!!!
              Originally posted by SamE30e View Post
              Transmission, very top bolt..
              4 extensions, 2 swivels, and a torx socket and about an hour of your time. Oh and infant hands would help too.
              That's the way I did it. Be sure to raise the front of the engine as much as you can. It helps.
              Been over a year and it still doesn't the other motor mount made...
                Originally posted by browntown View Post
                Subframe brake lines. Don't bother, drop the subframe
                Bah. I'm going to argue this one.
                I've done it twice. Once you have the right wrenches it takes no time at all.
                '88 325is
                VP UT of Austin Autoholics
                BMWCCA 380364
                  if you have access to a lift it is easy.
                  1 swivel & a 3ft extension & 1/2 inch impact.
                  i work & a tranny shop & these are the tools of the trade.
                    Originally posted by rede30 View Post
                    The first three on your list i have down, still no fun though. I always dread the right front control arm because of that middle 19mm bolt. I have a technique but it still takes quite some time. I need a ratcheting 19mm wrench to end my pain.
                    Yeah, that one had me stumped too. If you are talking about the M20, then I think it is 22mm. I just broke the engine mounts loose, lifted the engine with a jack as much as I dared, spun the stupid engine mount heat shield out of the way and then dropped the right side of the subframe about 1/2. You just loosen two bolts on the subframe to do that. This gives you enough clearance under the exhaust manifold to get the socket on.
                    After that, I could easily get the socket in from above with an extension and a universal. You can even torque to spec this way :D
                    I hear that the M42 is more of a problem though.
                    I'll be doing the bitch clip in the next few days... wish me luck.
                    1987 E30 325is
                    1999 E46 323i
                    RIP 1994 E32 740iL
                    oo=[][]=oo
                      Is that with just dropping the trans support brace or are you raising or lowing the motor?
