Getting AFM wheel back to where it should be.
  • rwh11385
    lance_entities
    • 18403
    Did the M30 AFM swap. Little detail: friend played with wheel when I wasn't looking.
    Dyno A/F reading said it was running rich. How can I tune it back to where it should be?
  • rs4pro3
    • 5808
    you can fine tune the mixture with the screw under that little cap. other than that, i'd buy an air fuel ratio guage and mess with the wheel location till you find a good AFR at idle and WOT.
    85 325e 2.7 ITB'd stroker
    • M-technik-3
      • 18946
      Or buy mine. 8)
      • E30godz
        • 1524
        on my afm, the stock location was two full turns left, from all the way closed (right).
        however, each car's AFM is slightly different, notice the small 3 numbers by the adjustment screw. i believe that has something to do with it.
          • 34844
          FYI, I scratched some marks on the wheel when I took it apart so I could set it back to the factory spot.. dunno if you were using the same posistion though.
          • rwh11385
            lance_entities
            • 18403
            Dude, you rock.
            I'm going to try to find them. Where were the marks, in the middle on the two spring, or what?
            When I get dressed, I'm going to pop that bitch. I just woke up.
              • 34844
              they are on the outside, near the teeth. it should line up with the spring/wire thingy that goes into the teeth.
              • rwh11385
                lance_entities
                • 18403
                Thanks. Great thinking, btw.
                I went out, popped the cover off, found the notch, moved it to the right place. Drove it, then resealed cover.
                The notch was over a ways from where it should have been. About where the other wire was. Moving it to where it was stock was the way you turn to make it lean, I believe. So that should take care of my car running a little rich.
                Thanks!
                  • 34844
                  np.. glad I made that mark!
