Gathering parts for 5 speed conversion
  • Digitalwave
    is a poseur
    • 6293
    Already, well I already have every basic part that I need from an 87 325iS parts car. This is what I plan on replacing:
    Clutch kit (clutch plate, pressure plate, throw out bearing)
    Lighten the stock flywheel
    Pilot bearing
    All the shift linkage, including a shorter throw lever (got the part numbers for this)
    Guibo
    Center support bearing
    Tranny mounts
    Seals
    Now, the seals are the main thing I am unsure about. Which seals will I need? Part numbers? Any other various parts? I know that Bill recommended the pressure plate bolts.
    For those that think this is out of the blue, please see my other thread:
    RISING EDGE
  • aaron_silva
    • 1785
    On Dave's stroker project, he replaced some seals while the tranny was out. You might want to check with that.
    HTH
    Aaron
    • M-technik-3
      • 18946
      Engine rear main seal, transmission seals at input end and output as well as shifter seals.
      • Bill 84 318i
        • 1600
        Get both new flywheel bolts and new pressure plate bolts. Also new exhaust gaskets, which are easy to forget.
        Get a new pivot pin, and for peace of mind, release lever. I try to replace self locking nuts whenever I can as well.
        For the rear main seal, don't forget a gasket for the seal carrier (which I think M20's have like M10's...but I don't have my ETK with me).
        • randomtask37
          • 3154
          i have a 4.10 for you if ya want it.
          98 M3/4/5
          • Digitalwave
            is a poseur
            • 6293
            I already have 2 different 4.10's :)
            RISING EDGE
            • Digitalwave
              is a poseur
              • 6293
              I can't find a rear main seal, could it also be called the rear crankshaft seal? Around $10-15? And then the seal carrier gasket called the rear crankshaft housing gasket?
              Ehxaust gasket is only for the manifold/cat connection right? Do M3's have the same gaskets? That's all I can find.
              RISING EDGE
              • Digitalwave
                is a poseur
                • 6293
                Ate Super Blue $ 9.95 $ 8.96 * $ 17.91 Delete
                Brake Caliper Kit (Front) $ 7.95 $ 15.90 Delete
                Brake Caliper Kit (Rear) $ 7.95 $ 15.90 Delete
                Clutch Kit, Sachs $ 150.95 $ 150.95 Delete
                Transmission Mount $ 6.49 $ 12.98 Delete
                Shift Shaft Seal $ 2.35 $ 2.35 Delete
                Output Shaft Seal $ 2.95 $ 2.95 Delete
                Input Shaft Seal $ 6.95 $ 6.95 Delete
                Clutch Lever Pivot Pin $ 0.86 $ 0.86 Delete
                Clutch Fork Lever Spring $ 1.06 $ 1.06 Delete
                Clutch Fork Lever $ 9.25 $ 9.25 Delete
                Flex Disc, Driveshaft $ 32.95 $ 32.95 Delete
                Center Support Bearing $ 30.95 $ 30.95 Delete
                Flywheel Bolt, 12x50mm $ 1.70 $ 13.60 Delete
                Felt Washer, Pilot Bearing $ 0.60 $ 0.60 Delete
                Cover Plate, Pilot Bearing $ 0.40 $ 0.40 Delete
                Cover Plate, Pilot Bearing $ 0.79 $ 0.79 Delete
                Pilot Bearing $ 3.95 $ 3.95 Delete
                Crankshaft Seal, Rear $ 11.95 $ 11.95 Delete
                Gasket, Rear Crankshaft Housing $ 1.89 $ 1.89 Delete
                Exhaust Gasket, Cat\ Flange $ 12.79 $ 25.58 Delete
                Redline MTL Gear Oil $ 7.19 $ 14.38 Delete
                Redline 75/90 Gear Oil $ 7.19 $ 14.38 Delete
                That is what I have come up with. Couldn't find the pressure plate bolts.
                RISING EDGE
                • Sean
                  • 5793
                  Exactly what he said regarding seals.
                  I'll be purchasing pretty much the same things soon for my clutch job - where you buyin all your stuff from?
                  BTW - you should get a SPEC Clutch... ;)
                  - Sean Hayes
                  • James Crivellone
                    Head Janitor
                    • 6304
                    Where are you buying the clutch from?
                    • Digitalwave
                      is a poseur
                      • 6293
                      BMA Auto, one of the best companies out there, is price matching www.eap4parts.com's rediculously low prices. $150 for the clutch kit! $27 for the guibo! The guibo is almost $60 at the dealer.
                      RISING EDGE
                      • Jand3rson
                        • 37587
                        What kind of clutch kit is it? Because as you know, I may end up needing one too!
                        • Digitalwave
                          is a poseur
                          • 6293
                          Sachs OEM.
                          RISING EDGE
                          • Jand3rson
                            • 37587
                            Sachs OEM.
                            Damn dude, for $150, are you serious?
                            Bavauto wants like $224!
                            • James Crivellone
                              Head Janitor
                              • 6304
                              Thanks for the link bro, that is much less then BavAuto, an d 27 for the guibo is damn good
