Turn signal question
  • grlaneriejr
    • 321
    Hey guys, I got a problem.
    At lunch today, my driver side signals won't work. Even the light in the dash won't blink. Anyone know what's up? The passenger side works fine.
    Thanks
  • kencopperwheat
    King of Kegstands
    • 14396
    Reach behind the bumper and make sure that the plug on the rear is snug on the turn signal housing.
    Originally posted by Gruelius
    • James Crivellone
      Head Janitor
      • 6303
      Check all Fuses, also check the harness that runs to the Turn Signal Switch, and verify the relay is nice and tight
      • e30evolution
        West Werks
        • 1888
        :up: if the plug on the light was loose it wouldnt stop the dash indicator from working
        http://www.westwerksauto.com
        • grlaneriejr
          • 321
          The dash indicator doesn't work, and neither do the lights on the outside of the car. Just the driver's side.
          Would the relay affect this? Where is the relay located?
          • M-technik-3
            • 18946
            Do your hazards work? yes check other issues if not repace bulbs check for corrosion.
            • grlaneriejr
              • 321
              I will check them in a little bit. didn't think to check them
              edit:
              just checked hazards. they do not work on either side. I'll check bulbs tonight.
              • grlaneriejr
                • 321
                Just changed bulbs, fuse. Still no signals on driver's side.
                Relay maybe? is it under the dash or in the engine compartment?
                HELP!
                • James Crivellone
                  Head Janitor
                  • 6303
                  Check the connector that goes into the back of the Hazard Switch, also check the Turn Signal Swith harness as I said earlier =)
                  • grlaneriejr
                    • 321
                    okay. i will check that tonight. thanx
