Worthwhile upgrade?
  • Digitalwave
    is a poseur
    • 6284
    Worthwhile upgrade?
    While my car has downtime I was thinking about installing an M3 rear sway bar, and M3 front pickup links. Would it be worth the money? I found a rear bar locally for $50. I know its not a big upgrade, but I want to get stiff GC's sooner or later (sooner) and I know you are supposed to tune with springs, not sways. Would I feel a difference with this stuff?
    RISING EDGE
  • Rob
    • 8166
    if you're getting stiff GCs later, dont bother with sways.
    BEERTECH
    • M-technik-3
      • 18946
      Two differant logics here, ride comfort with springs or turn in response with sways.
      What are you looking for? You can acomplish a flat cornner with either or.
      • Digitalwave
        is a poseur
        • 6284
        I don't think that the rates I would get with GC's would be absolutely stiff enough to run stock sways, but not soft enough to warrent something like ST sways. And the springs I have now would definately benefit from sways, so I am just wondering if the above mentioned setup is a decent upgrade.
        RISING EDGE
        • aaron_silva
          • 1785
          I think you should shop around for another sway. $50 seems a bit steep (got mine for $30). I think it is worthwhile. If you can weld up new brackets and get the drop links for cheap, then you should do the front also. Either that or get a cabrio front bar (21mm).
          Aaron
          • Digitalwave
            is a poseur
            • 6284
            Well on s14.net one guy wanted $150 for the bar and the links, and another guy wanted $75 for the bar :roll: I don't know where to find one cheaper.
            RISING EDGE
            • Rob
              • 8166
              I simply dont think they would be a huge upgrade over stock, and any improvement would be overshadowed once you got a properly set up GC er, setup
              BEERTECH
              • aaron_silva
                • 1785
                Agreed.
                Aaron
                • Digitalwave
                  is a poseur
                  • 6284
                  Alright, guess I will put my money elsewhere.
                  RISING EDGE
                  • Bill 84 318i
                    • 1600
                    Generally, you tune with sways, not springs.
                    • Beej '86 325es
                      • 2639
                      I would just wait and put on the G-C's first. You'll see that even with soft springs on that kit, it drastically reduces body roll. I installed ST bars later on and really just improved turning response and only slightly improved body roll over the stock bars.
                      -Brandon
                      '86 325es S50
                      '12 VW GTI Autobahn DSG
                      '03 540i M-Sport (sold)
                      '08 Jeep SRT-8 (sold)
                      For sale:
                      S50 TMS chip for Schricks
