Restoration type oil?
  • bimmer8604
    • 3017
    My dad asked me today if such oils, as the Moble 1 oil that is designed for high milage motors that says its "restores" the internals, is worth it. Well, thats what i'm asking you guys. Is it something you just put one quart of it in and use the regular oil for the rest, or all the one type? Do you use it every time you change your oil? Or just once? I have no clue, all i do for my motor is run a fuel system cleaner about every other month or so.
    TIA
    kyle
    1988 M3, 97 840, 99 XJ
    DILLIGAF
  • Brian 89 325i
    • 1450
    Im doing a little test on it, to see if it slows comsumption. So far i havent seen anything impressive. Im using Castrol High Milage 20W-50
    Brian
    • Digitalwave
      is a poseur
      • 6300
      Brian
      That's what I do. All I've noticed is it quiets my valvetrain a little. I am happy with it, and its only like $0.20 more a quart.
      You are supposed to use it everytime you change your oil, and your use all 5 quarts of it, not just 1.
      RISING EDGE
