New E30 - Initial Plan
  • KeithV
    • 186
    Recently I came into an 89 325i. I've run through everything and begun a list of things I need to replace/upgrade.. Wanted to run it by everyone and see if I've missed anything..
    Batch is the grouping I'll do the ordering in.. so Batch 1 will get ordered first, etc. U/N is Unnecessary or Necessary, and the rest is self explanatory.
    UPDATED: New list with changes
    1991 Diamondschwarz 325i 5spd (SOLD)
    1989 Zinno 325i 5spd (NEW)
    2000 Nissan Maxima GLS Rollin' Phat (DD)
  • Dave
    E30 RAT
    • 11675
    Unless you know its been done recently, I'd make Batch "0" the timing belt and water pump. Heck, for the cost of it, I'd do it anyway unless it was a realtive's car and you know first hand it really has been done.
    Have a search and find the other "while you're in there" parts if needed.
    Current Cars
    2014 M235i
    2009 R56 Cooper S
    1998 M3
    1997 M3
    • KeithV
      • 186
      tbelt and waterpump were done ~500 miles ago.
      • Dave
        E30 RAT
        • 11675
        excellent - looks like you have a good plan of attack then.
        Current Cars
        2014 M235i
        2009 R56 Cooper S
        1998 M3
        1997 M3
          Unless you have evidence to suggest that it is bad, I'd delete the coil from your list. Coils rarely fail and the OE coil provides plenty of spark. I'd also delete the rear shock tower brace as it isn't needed. And I'd use either the Rogue or GC rear upper shock mounts (Bimmerworld is one source).
          I would definitely include motor, transmission. and differential mount in the group 1 list.
          • NC325iC
            • Mar 2004
            • 6565
            are new springs in the plan along with the sport shocks?
            new control arms are a good plan as well
            • KeithV
              • 186
              Thanks for the input. I updated the list again. I deleted the rear shock bar, coil, and OEM rear shock mounts, and added the GC rear shock mounts. I also consolidated the shocks/springs down to a bilsten/HR kit provided by Turner.
              As for the control arms, is the upgrade to M3 alum arms worth it? Or should I just replace with OEM.
              • JGood
                • Jan 2004
                • 7959
                What are you using the car for? If it's street use, the M3 control arms aren't really an "upgrade".
                Make sure you get Lemforder suspension parts, they are the best, although a little more expensive. BMA gives brand names, that's who I would go through. Might wanna get tie rods and sway bar links too.
                Don't forget all the hardware... new hose clamps for your new hose kit, etc...
                e30 restoration and V8 swap
                24 Hours of Lemons e30 build
                • VacMan
                  • Apr 2007
                  • 2405
                  Your list is gone.
                  • KeithV
                    • 186
                    A Summer street car and occasional atuox. My 91 was my DD, but this time around I have two cars. The hose kit comes with all clamps etc needed.
                    One thing I need to figure out is what's going on with my radiator. I bought the far from Doug Thoms, the Chief Instructor for the NOC CCA. He replaced some front end components after a "minor" front end colission. Other than the hood being a little off it all looks good, except for the radiator. Both large coolant pipes are on the bottom, rather than one being on the top left and one on the bottom right. There are also two sensors threaded in with no harness connected.
                    Anyway... other than that it's all good.
                    • KeithV
                      • 186
                      Originally posted by VacMan
                      Your list is gone.
                      Shows up for me.
                      • JGood
                        • Jan 2004
                        • 7959
                        I'm not seein it...
                        • Bimmerista
                          • Nov 2005
                          • 5425
                          I see it
                          • KeithV
                            • 186
                            I'm looking through my server logs and I don't see any refusal errors on that file. I have hotlink protection but www.r3vlimited.com and r3vlimited.com are exceptions.
                            • VacMan
                              • Apr 2007
                              • 2405
                              Still not there. Why don't you just copy and paste it into a post here?
