Is there a differance between the high beam reflector & low? Is 96.00 too much for the 55w low beams with Bosch reflector?
Bosch H4 Conversion kit BMW E30 318 325 320 323
If i were you i wouldnt go H4/H1 setup. I went that way. I got the Bosch H4s and then got Osram silverstars. Its not even half as good as ellipsoids and H1 silverstars will give you. + in the end i ended up paying around 120 for the lowbeams alone, I coulda saved a little more and got a used set of smilies which look way better and are much brighter. However, The H4s are a big step up from sealed, but not half as good as ellipsoids.
my 2 cents90 325is
IE stage 3s and refeshed m20....
I got some Hella H4's and they are quite the badass. It made a HUGE difference in nighttime driving and I only got the 55w's. I saw they had an H4 bulb that was 100w/150w I might change to that for an even greater increase in light output (lots of backroads hi-speed highway driving with lots of deer) but its not necessary with just the 55w bulbs.
Originally posted by MikesJoOriginally posted by 318driverThere are always tons of sets on ebay... There is a bit of an install issue but i dont think it is anything major. I havent looked into the swich fully yet, but i know many have and im sure they will chime in soon90 325is
