why can't you "retension" the timing belt
  • ptownTSI
    • Jun 2005
    • 1265
    I don't get it, it is already under tension. what is the big deal if that is released and then put back to where it was. how does it shorten its life by doing this?
  • Teaguer
    • Sep 2004
    • 6167
    Because it is old school shit technology that only last 60k if all is right anyways .
    You can remove/replace the water pump without removing tension if that is your reason .
    • ptownTSI
      • Jun 2005
      • 1265
      no i'm going to be pulling the head to replace a broken rocker on the intake # 1 cyl, just didn't get why i needed to change the belt if i've only put 1000 miles on it since i did the thing.
      • Teaguer
        • Sep 2004
        • 6167
        Haha don't be a cheap ass , how much is a new belt ..like $15 ? :p
        • ptownTSI
          • Jun 2005
          • 1265
          i drive an e30 and i'm on r3v... lol. btw whats up with the 5 lug swap photo shop wheel and did you chop the bumper onto that too with the rusty fenders and red hood?
          • Charlie
            kid tested, administrator approved
            • 6686
            Dude, it's a $15 part that becomes a $1500 part if you fuck around, just replace it.
            -Charlie
            Swing wild, brake later, don't apologize.
            '89 324d, '76 02, '98 318ti, '03 Z4, '07 MCS, '07 F800s - Bonafide BMW elitist prick.
            FYYFF
              • 34846
              you can, if it's new - I've put about 25k on a retensioned belt (it was new, no miles when I took it off and put it back on). but yeah, it's a cheap part, no reason to chance it. I only did it because A) I can get away with a broken belt and B) I wanted to get my car running that day, I didn't have time to wait for a new one. Also, I wanted to know if it could be done, because everyone always says no. ;)
              • ptownTSI
                • Jun 2005
                • 1265
                i wanted to know specifially why you can't, i'm going to get a new one. but physically what is it about the belt that means it can't be retensioned? you can retension a serpentine belt as much as you want.
                  • 34846
                  nothing, like I said - you can retension it. but you're taking a risk that a $15 part won't fail and cause $2000 worth of damage. Ergo, just replace it. why take a chance?
                  • E30_fiend
                    • Apr 2006
                    • 7348
                    just don't risk it bro. Its something that is inexpensive that can become very expensive if it decided to go. You could always build a non impedance motor instead of spending 15 bucks on a belt. Lol
                    Kinda off subject but why are you taking the head off to replace a rocker? Did you bend a valve or something?
                    E30Fiend
                    • -Javier-
                      • May 2007
                      • 382
                      i say just replace it.
                      • DCColegrove
                        • 2748
                        The reason is that the internal cords may separate once tensioned then slacked off and tensioned again (works them around in the rubber).
                        The price of the belt is cheap insurance.
                        The recommended interval on M20s is 4 years or 50K (it changed...actually I wrote TSB on it in the early 90's) because we found a whole shit load were failing long before 60k.
                        I would personally (and if you drive like I do) replace the belt every 30K.
                        I just picked up a '90 2 door I for $50 because of a t belt failure...any one got some new valves for an 885 head they wana sell cheap?
                        • DaveSmed
                          • Apr 2007
                          • 1407
                          If you do decide to reuse it, reinstalling the belt with the correct rotation is critical. Mark it before you take it off.
                          ....but really..... $15.
                          -Dave
                          2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
                          Need some help figuring out the ETM?
                            • 34846
                            I have a used set in decent shape (no bending or anything).
                            • ptownTSI
                              • Jun 2005
                              • 1265
                              I don't think you can replace a rocker without pulling the head? it is the #1 intake valve rocker that broke. if you can, let me know how!
                              I am going to get a new belt as well.
