Rear wheel 'leaning' inward about 5degrees...causes?
  • Eviltwin
    • Mar 2008
    • 323
    Just noticed this on my car...my passanger rear wheel seems to be "leaning" inward about 5-10 degreed from the top.
    almost looks like I'm running a camber issue on one wheel.
    I'm running stock springs right now.
    now bearing noises, or anything.
    Thoughts?
    just an alignment needed? could be something major?
  • SamE30e
    • Sep 2007
    • 4319
    Subframe cracked? Mine was like that.
    1985 325e 2.8 Turbo VEMS
    • wagonizzle
      • Sep 2006
      • 443
      No factory rear adjustments possible. Start looking for worn/broken/missing parts...
      Originally posted by chileelky
      amaze about the enthusiasm e30 generate
      • Eviltwin
        • Mar 2008
        • 323
        I'm hopeing it's worn as f*ck springs/shocks...as I'm tossing in bilsteins/voglands soon.
          • 34847
          worn out TABs, subframe bushings, and/or a bent subframe/trailing arm can all cause that.
          • Eviltwin
            • Mar 2008
            • 323
            would trailarm bushings be a "while i'm there allready" kind of job while i'm putting in new shocks/springs?
            • Jean
              • 18228
              they are pita, and if you are going to do them might as well do the other side and/or subframe bushings at the same time.
              • redhatpat
                • Aug 2005
                • 656
                Some negative camber, ok. But 5-10*? Sure sounds like something's broken.
                Yeah, sure, that'll fix it.
                Uh, you're not driving it like this, are you?
                  • 34847
                  more broken than a bent trailing arm/subframe and cracked bushings? that could easily cause a large difference in camber.
                  • Eviltwin
                    • Mar 2008
                    • 323
                    alright, so it seems I may of overestimated the "10 degree" value.
                    I'd say it's leaning ever so slightly towards the left...
                    I took a pic, you can barely make out the lean...
                    either way, I"m going with TAB cracked bushing along subframe as prev. mentioned.
                    • Eviltwin
                      • Mar 2008
                      • 323
                      fixorzed.
                      ended up being my oem stock springs that were beyond dead, causing the car to lean, and causing slight camber.
                      bushings, were allready replaced by P.O.
                      replaced with H&R's.
                      now you can all rest, without worrying about this :pimp:
                      • TrackAddict
                        • 111
                        I have a similar problem. My car is lowered and has the Turner Motorsports J-stock suspension kit installed by a previous owner. Both rear wheels have about 4-5 degrees of negative camber and so far the consensus is that the subframe bushings are shot. Do springs actually wear out to the point that they'll cause this much camber?
                        • golde30
                          • 11464
                          if yer stupid low and dont have a rear camber correction kit, yer looking at -3+ camber on the rear.
                          IG: @Baye30
                          • Justin B
                            Sikky Nar Nar
                            • Mar 2005
                            • 4273
                            I dunno what my camber is in the rear but with race springs and no pads in my cabby it's probably pretty close to that :P
                            • StereoInstaller1
                              GAS
                              • 22679
                              Trailing arm bushings, perhaps...but subframe bushings, no way.
                              Closing SOON!
                              Thanks for 10 years of fun!
