tranny question
  • 88325isboy
    • Mar 2004
    • 1058
    tranny question
    hey will a 325e tranny fit on my 325is? my buddy thinks that is will not work. i thought that is would be i dont know so some one help me out on this one.
    thanks
    Bobby
    '87 325 (Track Rat)
    '04 C5500 Wrecker (Work)
    '94 525i (Daily)
    '90 325i (R.I.P)
    H&R Race, Racing Dynamics Sway Bars, Tree House CAB's, Sparco Strut Bars and more.
  • James Crivellone
    Head Janitor
    • 6305
    Will work fine, you may have to change the output flange, and make sure the shifter assembly is the right year
    4/86 and older cars used a different shifting design. so make sure the tranny is 5/86 and newer and you should be alright
      • 37833
      Ya, what he said. Althought you can not put a 325i tranny on a 325e. [Damn BMW]
      Grover Beach, California
      BimmerHeads.com
      • 88325isboy
        • Mar 2004
        • 1058
        thanks alot for the info guys. the tranny is out of ryan stewart's car a 1984 325e and my car is a 1988 325is. So i will have to change the shifter on that tranny? and can i use that eta imput shaft or not.
        thanks alot
        Bobby
        '87 325 (Track Rat)
        '94 525i (Daily)
        '90 325i (R.I.P)
        • AdamF 88iS
          • 2051
          You can't change the shifter setup on the tranny like that because the bracket for the later shifter is part of the tranny case. You'll have to put the entire shift assembly onto the later car to use that old tranny.
          Adam Fogg- '88 M3
          Common sense- It's the new 'gifted'
          • chesster6969
            • 321
            Which year 325e transmissions had the proper output flange to work in a 89 325i?
            Which year 325e's have the sheet metal consoles and are the gearings different for certain years?
            • James Crivellone
              Head Janitor
              • 6305
              Outflange: I don't think any ETA Transmission has teh correct flange, I looked around for awhile at tons of ETA tranny's and just decided to buy one, easier to change the flange then to hunt around for something that I don't think exists.
              4/86 and older have the sheet metal consoles, Gearings are the same on all Getrag 260's to my knowledge
              • Ryan Stewart
                I Love Miatas
                • 8978
                Guys, I dont know this crap so maybe you need more info. His car is a 325i automatic so he doesnt have any of he regular shifting linkages and such. He is basically doing an auto to manual swap with my transmission if possible.
                Would all the parts used for the swap be compatible with my tranny? Mine is an 85 built in Novermber of 1984.
                Im now E30less.
                • chesster6969
                  • 321
                  So would the outflange be a problem if I use the eta trans, driveshaft,guibo,center bearing, and 3.73LSD diff?
                  To convert an 89 325i auto to manual of course
