Anyone ever fitted a hood-prop rod?
  • Jand3rson
    • 37587
    I was thinking about this the other day, has anyone every installed a hood-prop rod on an E30? You know, like the ones they have on cars whose hoods open the normal way? My hood shock works just fine, but even if there's a stiff wind, it will still blow it down. After being out at the autocross this weekend and having my hood up a lot while checking things between runs (while VERY windy), I was thinking that this would be a really nice thing to have. Has anyone ever done it, and if so, which one did you use, and do you have pics?
  • lordofthewaters
    • Oct 2005
    • 714
    I don't think it'd be hard, you could probably pirate from any number of vehicles. Especially if one has rudimentary welding skills.........
    Sarcasm is a body's natural defense against stupid.
    When a man talks dirty to a woman, it's sexual harassment. When a woman talks dirty to a man, it's £3.95 per minute.
    "My mother never saw the irony in calling me a son-of-a-bitch." Jack Nicholson"
    Old age and treachery will always overcome youth and skill.
    • Jand3rson
      • 37587
      I don't think it would need to be welded, you could just mount the hinge/base plate to a flat surface in the engine bay with self-tappers, then just paint/seal it.
      • george graves
        • 20003
        Getto - but maybe a length of 1" diameter PVC pipe with a channel cup out of it length wise that you could slip over the stock hood shock?
        No welding, cutting, tapping, ect. Easy to keep in the trunk.
        Originally posted by Matt-B
        • browntown
          • Jun 2004
          • 3524
          I used a sawed off broom handle for a while. worked fine.
          • Jand3rson
            • 37587
            That's not bad, George. Not bad at all.
            The broomstick is a no-go.
            • george graves
              • 20003
              Thanks!
              Either that of a 1" piece of bar stock. Cut a slot as show, and tap for a thumb screw on the end. Slide it onto the shaft and tighten the thumb screw to limit the shocks travel. But it might mar the hood shock and ruin it.
              .....___..........|......|XXX|
              ....|....|.........|/////|XXX| <-thumb screw
              .....\....\........|.......|XXX|
              ^bar stock
              Sorry for the ASCII art.
              (You can make almost anything out of crap from the hardware store.)
              • backtrail69
                • Jul 2005
                • 4471
                Vise grips on the hood shock. :razz:
                :: PNW Crew ::
                '87 325 4dr, '74 2002
                • golde30
                  • 11464
                  i been thinking about this also, as i must have had my hood blow shut on me a dozen times over the years.
                  IG: @Baye30
                  • NC325iC
                    • Mar 2004
                    • 6565
                    did that for a while
                    • AlarmedBread
                      • Sep 2006
                      • 1510
                      FTW.
                      • AndrewBird
                        The Mad Scientist
                        • 11898
                        How about something like this:
                        http://www.amazon.com/Lisle-45900-3-.../dp/B0002BC0T6
                        Or maybe just get a new gas strut that is stronger. All you would have to do is measure the length compressed, the length extended and then calculate the force needed. It might even say on the stock prop somewhere. McMaster has a TON of them.
                        • TwoJ's
                          • Oct 2005
                          • 4908
                          I can't visualize the shock in my head right now, and I'm too lazy to go out to the garage, so this may not work, but why not just pit a pin on the hood hinge where the to lever arms overlap? This would effectively taking the shock out of the picture. And all you need is a pin and a drill...
                          Plus, it won't look extremely ghetto.
                          • golde30
                            • 11464
                            something like this mite work. i will take a look at mine 2m.
                            IG: @Baye30
                            • jimsill
                              • Nov 2005
                              • 548
                              on a related note, when i installed my m-tech 1 spoiler a few years ago, it totally over-powered the effectiveness of my trunk shock, which worked fine prior to the spoiler. Is there a spoiler specific trunk shock, or was mine just on the verge of dying when i installed the spoiler?
                              both these cars are gone :(
