Power sunroof conversion
  • Digitalwave
    is a poseur
    • 6299
    I am removing the power sunroof parts from my parts car to be used for a conversion. When removing the motor, do I have to remove the tracks and all that jazz? Are those parts the same on crank sunroof cars? Can I just remove the motor, and sell that for the conversion?
    RISING EDGE
  • DanGillan
    • Mar 2004
    • 4061
    im really interested in doing the conversion, have you seen any write ups anywhere? let me know when your done pulling parts, i might buy em off you.
    Dan
    • decay
      • 5637
      ooh, i'll be interested in hearing the answer for this as well.
      past:
      1989 325is (learner shitbox)
      1986 325e (turbo dorito)
      1991 318ic (5-lug ITB)
      1985 323i baur
      current:
      • bimmerphile
        • 3495
        TJ:
        These are the following parts you'll need for the sunroof conversion:
        Black overhead panel (headliner)
        bracket for sunroof cable
        bracket for sunroof motor
        sunroof motor
        switch
        relay
        wiring harness
        The difficult part is taking out the old bracket (from the crank) without cutting the headliner. If you do cut it, it will be covered by the black headliner piece, so it's not a big deal (just re-stitch it together).
        -Kris
        • decay
          • 5637
          you have to switch the whole damned headliner? phooey.
          past:
          1985 323i baur
          current:
          • kencopperwheat
            King of Kegstands
            • 14396
            No, just the black one in front; the one that holds the visors.
            Originally posted by Gruelius
            • bimmerphile
              • 3495
              bingo.
              One has an opening for a switch, the other for a crank.
              • decay
                • 5637
                i guess i haven't looked at my headliner closely enough. thanks :)
                past:
                1985 323i baur
                current:
