engine block painting....
  • george graves
    • 19993
    I've never painted a engine block before - how the heck to I get rid of rust and paint the sucker?
    I'd love to be left with a thick looking coat of glossy paint- almost like a thick power coat - looking finish....
    Any advice?
    Originally posted by Matt-B
  • aaron_silva
    • 1785
    Wipe it down with a rag to get the loose stuff off and paint it. It should turn out.
    Aaron
    • george graves
      • 19993
      look at the block - that rust has etched it's way into the block...wipe it with a rag?
      Dam - I was thinking of getting a brass or steel brush and scrubb it - or a circular brush mounted in a rotary air tool...
      a rag? are you high?
      • aaron_silva
        • 1785
        I dont think you will ever be able to get a "smooth" finish. Just make sure all of the loose stuff is off and then shoot it.
        Aaron
        • kencopperwheat
          King of Kegstands
          • 14396
          Get some wire brushes and remove as much as you can. Then get some Naval Jelly Rust Dissolver (Thick pink liquid you can get from Home Depot for $5 or so). Apply it generouly to the block and let the phosphoric acid dissolve the rust. Then spray it all off.
          Originally posted by Gruelius
          • george graves
            • 19993
            cool...
            • Jordan
              • 12911
              Nod on the navel jelly. I used it to remove a few spots I had on my car so they could not come back. A wire brush will help.
              https://mtechniqueabs.com/
              • rs4pro3
                • 5808
                I plan on starting to paint my block tommorow, I painted an m20 before and just got all the grime off then lightly sanded it to remove most of the rust and painted it.
                I just got my lower gasket set in the mail and my Oil pump, and some other parts are supposed to be here soon.
                I Plan on painting the block with some high temp black paint I used on a set of I exhuast manifolds that looked awsome when finished.
                85 325e 2.7 ITB'd stroker
                • bmw335ist
                  • Apr 2004
                  • 100
                  I used a high temp gloss black but before I did that I used a high strength degreaser and a light acid it removed every thing with out hardly any scrubbing.
                  • ChocolateKrackers
                    • Mar 2004
                    • 233
                    You can hide pox well with a black paint but if you want to do something else a little wet sand and soap then blow it dry with a compresser then straight to paint.
                    "My backpack's got jets..."
                    ~MC Chris is my co-pilot~
                    • rs4pro3
                      • 5808
                      I just got done cleaning my block. It turned out great. I stoped by Walmart and got a couple cans of Engine Degressor, Sprayed it on and went to work scrubbing with a steel wire brush. After 3-4 treatments and rinses the block is clean to the touch. All the loose rest is gone, along with the grime, and some of the origanl paint on the block. Once I get the Crank nut off, and the timing cover off I'll clean it one more time and then paint it.
                      • george graves
                        • 19993
                        Tried navel jelly on a flywheel last night - let it sit for 5 mins - hosed it off - didn't really do anything...how long did you guys let it sit?
                        • kencopperwheat
                          King of Kegstands
                          • 14396
                          At least 4 times that long. And you'll probably have to do it 2-3 times to get it all off depending on how much rust there is. Use a wire brush to get most of it off first.
                          • rs4pro3
                            • 5808
                            Ok here are some pics of my cleaning.
                            Dry
                            I see now how the older and newer M30 mounts differ.
                            • LikeCDoos
                              • Jan 2004
                              • 2522
                              maybe invest in a sandblaster ($12 at homedepot)...well that is if you already have a compressor handy
