Surging Eta! Help!!
  • SpartanTiger81
    • Sep 2007
    • 555
    Surging Eta! Help!!
    When I'm going uphills it seems to start doing it. I changed the spark plugs with Bosch platinums and the fuel filter yesterday, and still doing it. I ran some gas treat and injector cleaner through it, and it was a no go. I cleaned the filter also. Please help! Running out of ideas!
    • 37829
    Almost every Eta I have driven has this problem. A performance chip takes a lot of it away actually.
    By the way, Platinum plugs are not correct for the M20.
    Classic BMW Specialists
    Grover Beach, CA
    www.BimmerHeads.com
    • //MPower
      • Jun 2007
      • 182
      Mine does the same thing. Still haven't figured it out.
      | Jimmy | 1999 M3 | 1986 325 ES |
      • scabzzzz
        Estado de mierda de encargo
        • 6871
        Search. A billion threads about this. Its going to be troubleshooting time for you. Sounds like you're on the right start though.
        Check for vacuum leaks, AFM, ICV, etc..
        • Todd Black 88
          • Oct 2007
          • 3449
          In tank fuel pump, if it only does it under heavy load. Early cars had 2 pumps, and the intank pump fed the pressure pump. Pull the back seat, pull the panel on the left under the sound pad, pull the pump plug(not the sender) and check for continuity through pump. no continuity, no pump.
          Originally posted by codyep3
          I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
          2001 silver/Blk 325 cabby. SOLD
          2002 325xit Sil/blk. SOLD
          2010 F650gs twin
          • SpartanTiger81
            • Sep 2007
            • 555
            Bump* It does with no load to
            • Aptyp
              • 6584
              never had this problem with any of my E's
              I would check vacuum lines, ICV and the irritating little things like that. And take platinums out, get NGK V-plugs.
              • lordofthewaters
                • Oct 2005
                • 714
                Bosch WR9LS for the eats........
                Sarcasm is a body's natural defense against stupid.
                When a man talks dirty to a woman, it's sexual harassment. When a woman talks dirty to a man, it's £3.95 per minute.
                "My mother never saw the irony in calling me a son-of-a-bitch." Jack Nicholson"
                Old age and treachery will always overcome youth and skill.
                • ethree
                  • Aug 2007
                  • 1213
                  End of story.
                  German car = bosch or beru plugs
                  Japenese car = ngk
                  American car = champion or if you have a ford get autolites.
                  • RIDEOUTBOY
                    • 13
                    Is there also Rear FPR?
                    just wondering if there is another FPR in the back as well (right in front of the driver rear wheel), Looks like there is one when i peek under there. I'm have the same problem and just replaced all the cracked line in the enging bay and it helped mostly, except goin up the hill as mentioned before, (that is also the last line i havent replaced. the rear one right befor this "FPR" cause it didnt seem cracked). My car is an 86 ETA.
                    Thanks
                    • sennafan
                      • Jan 2008
                      • 205
                      I once had this problem and someone told me to get some throttle body cleaner and the car ran like new after that. I once talked to a guy who had a for sale sign in the window and his car was doing the same thing. He called and said he was keeping the car and that fixed it. Just a shot.
                      • expressfish
                        • May 2008
                        • 526
                        same deal here......86eta, surges at idle up and down and under a load/ almost flooring the gas it falls flat. I can find any vac leaks, plugs, cap rotor are all ruled out. I sprayed out my icv with carb cleaner...reinstalled and it did the same thing except at a higher idle. The in tank fuel pump is suppose to be new according to the shop who replaced it...along with fuel filter. Makes me want to check fuel pressure anyway. Im alittle fustrated myself as I a have the car completely stripped for paint...no lights ect, so I cant just drive it to a repair shop, much less want to pay someone else to troubleshoot it plus the tow there. Ive done all cooling hoses, injector rail o-rings--upper and lower--timing belt-cam seal-water pump and now Im stumped !!
                        [sigpic
                        • Todd Black 88
                          • Oct 2007
                          • 3449
                          Thanks
                          Its not a fpr. Its supposed to smooth out the harmonic pulses the fuel pump makes. Sort of a harmonic damper. Lots of people have removed them.
                          2010 F650gs twin
                          • Todd Black 88
                            • Oct 2007
                            • 3449
                            If you can get ahold of another known good AFM i'd swap it in and check if that helps.
                            2010 F650gs twin
                            • twinpop171
                              • Mar 2005
                              • 96
                              I was having the same issues with my eta as well.
                              Cap, rotor and plugs were all shot. Replaced them and the fuel filter and it helped a little.
                              Sea Foamed twice with no change.
                              Checked fuel pressure and had proper pressure at cold start injector but transfer pump in tank had zero pressure even though it was running. Replaced the pump and definitely helped climbing hills but had hesitation/sputter/surge.
                              Removed the fuel pulse absorber thinking it may be clogged or something but it wasn't and consequently didn't fix anything.
                              Cleaned ICV for the hell of it. It wasn't too gummed up inside but cleaning it made a difference with start up. Cleaned TB as well.
                              Tested throttle position switch and it tested good at idle postion but had no continuity at WOT. Replaced it and it was like adding 20HP. The surge/hesitation/stumbling was almost totally gone. I think the AFM was messed with at some point because the cap is removed. It may need a little tweak down the road. The throttle position switch looked clean and undamaged when it was on the car but when I took it off it was REALLY oil soaked inside.
                              Throttle response is way better too.
                              Sorry for the long post but I can totally relate to what you're going through.
                              Dan.
