Z4 ssk on an e30 m30
  • Xmarksthespot21
    • Jun 2004
    • 285
    Will the ssk from here (http://www.r3vlimited.com/phpBB2/vie...ght=z4+shifter) work fine with an e30 that has a late m30 swap?
  • Spaz
    Crazy Canuck
    • 2276
    what transmission do you have?
    Cam .W '91 325is
    Spaz's 1991 Alpine White???? S52 Build Thread...
    • rs4pro3
      • 5808
      yes go to www.mye28.com and search for Z4 lever. You'll find a good bit of info on it there.
      85 325e 2.7 ITB'd stroker
      • NewmanJ87
        • Jun 2004
        • 50
        I am currently putting a Z4 3.0 SSK together. Everything is fitting tgether good. The only thing I have had to do is file down the upper ball cup to fit it on the z4 lever.
        Jordan, when he has nothing bad to say, he says nothing at all. Cuz he's way better than us, right?
        • Xmarksthespot21
          • Jun 2004
          • 285
          Spaz,
          I'm using the Getrag 265 from an e30 m3.
          • Spaz
            Crazy Canuck
            • 2276
            Originally posted by Xmarksthespot21
            Spaz,
            you will have no problem installing any of the shift levers we speak up, i suggest using an z4 3.0L lever
            Cam .W '91 325is
            • Xmarksthespot21
              • Jun 2004
              • 285
              Thanks a lot.
              • Rob
                • 8166
                huh? can you explain this?
                BEERTECH
                • NewmanJ87
                  • Jun 2004
                  • 50
                  The upper ball cup isn't large enough to fit aound the z4 lever. Our stock levers were 2 peice ones that come apart, not the case with the z4 lever. So I had to file down the inner rim of the cup to make it slide on. A dremel drill works great.
                  OH yea, Some pple cut them in one spot so they can slide it on. I am not sure if either way is better. But one way or another its gotta go on. :)
                  • e30Matt
                    • 5077
                    If you mean the white nylon piece, it's supposed slide up from the bottom, by the pivot. That's why there's a "square" cutout in it, to go around the pivot.
                    • Bokes
                      • 1459
                      OT: do you know if the normal 325i transmission will work with an m30 swap?
                      173rd ABN
                      • kencopperwheat
                        King of Kegstands
                        • 14396
                        On the sheet metal console there are two of them. The bottom one has the square cutout, but the top one doesn't.
                        I rolled a piece of sand paper like a cone and just twisted the top one around on it. It fit like a glove afterward over the top.
                        Originally posted by Gruelius
                        • Xmarksthespot21
                          • Jun 2004
                          • 285
                          No the 325i tranny will not work. The bell housing bolt pattern is different.
