does this look safe to you?
  • dvmotorsports
    • Apr 2008
    • 658
    NO! Only because your driveway appears to have a slope in the pic. Maybe it's just the angle. But I would never get under a car lifted on a slope.
    Originally posted by jrhaile
    For the record I have never fucked a goat.
    • Sean T Sat
      • May 2008
      • 102
      the surface is kinda levelish but i mean i got an e-brake right or will that not work
      • dvmotorsports
        • Apr 2008
        • 658
        i personally wouldn't be comfortable with "kinda levelish". but it's your call amigo. there is no way i would get under anything on a slant that i couldn't pick up myself.
        • atomic
          • Jun 2007
          • 5691
          You wouldn't catch me under it !!
          • AndrewBird
            The Mad Scientist
            • 11898
            Oh come on. Thats what, MAYBE 1/4" per foot slope, which is standard for garage slabs.
            Looks perfectly safe. I agree on 2 more jack stands though. You could even put the rear stands 1 notch higher to even the car out if you feel so inclined.
            Also, if you do get more stands, put then sideways on the rear subframe as far out as they will go without being on the bushings.
            • Sean
              • 5793
              Yea, I suppose that angle isn't THAT steep. However, when I pull my motor, I pull out the tranny too, and there's tons of tilting going on with the motor. Yesterday, I even had to jack up the back of my car more (twice as high as the front) to get the motor out successfully. So, what I'm sayin is, with the car's nose pointed in the air like that, you WILL have trouble getting the motor out.
              If you guys think that's bad, I tried doing stands on my driveway once, and when I went to jack up the rear after the front was off the ground, the stands starting tipping.
              - Sean Hayes
              • Mastrcruse
                • Sep 2005
                • 5340
                Originally posted by Jean
                Two more jack stands ftw
                agreed. If your really worried, find a sale at anderson's and get 4 6 ton jackstands like me.
                I think the base of one is wider then the tires that are on the car.
                • redhatpat
                  • Aug 2005
                  • 656
                  It looks like the driveway is sloped? If so, those cinder blocks will just slide, and there's no way I'd trust a parking brake with my life. Get some proper wheel chocks (I built some out of 2x4's to fit my tires properly) and you should be good.
                  And at some point, you will need to lower the front to lift out the engine.
                  • Teaguer
                    • Sep 2004
                    • 6167
                    Never imagined this thread to go on for so long or have so many cry baby replies . :roll:
                    IMO if you have to ask this question then you should NOT be working on your car, take it to a nice independent shop .
                      • 34847
                      You'll have a hell of a time getting these motor out using a cherry picker on a slanted surface. That would really suck.
                      hey, I did it on a slanted surface, and it was on gravel!
                      yeah, it sucked ass.
                      • Sean T Sat
                        • May 2008
                        • 102
                        yo fuck that the money right there something i aint got much of. I just wanted to no if other people thought it was safe it looks fine to me : )
                        • Sean T Sat
                          • May 2008
                          • 102
                          and yea i got no idea what im doing. im learning!!!:)
                          • emi325i
                            • Oct 2006
                            • 356
                            I gave up the 2-ton jack-stands. I don't think they are stable enough. The base isn't big enough and they tend to roll.
                            Use 6-ton jack-stands!!!
                            • Teaguer
                              • Sep 2004
                              • 6167
                              Good man , carry on .
