i was told my steering rack was bad. it's got no belt on it, and i tried to put some atf fluid in just for kicks and it stayed in for the duration of a 30 minute drive (obviously no ps without belt) and when i turned off the car, the fluid all came pooring out of the steering rack boots... so, is my rack bad? should i hook up a belt and try again? thanks
how to spot a bad steering rack?
Tags: None
No, sounds like the outer shaft seals are gone, you could pull it and rebulid, or contact LPD in Duarte. You should be able to source a used unit, talk to David. -
well i could rebuild, but if im gonna get a new (used) steering rack i'd probably go with an e36 one... thanks for quick replyComment
hmm the diy writeup seemed like its not too difficult, i've got the tools. how hard is it to replace the outer seals? my dad works at a dealer so i can get the parts for cheapComment
Agreed.
OP, what are your intentions for the car?
If the vehicle is to remain as a nice, daily driven E30, then I would suggest just picking up a good condition, used E30 rack as they can be had for quite reasonable prices.Comment
i plan on going turbo... i love projects for the car and i'm probably gonna pick up an e36 rack from a scrap yard and experimentComment
