I have searched and received mixed messages on which oil to use for my next oil change. It is an 87 325is. thanks Matt
New to E30 325is What OIL?
Tags: None
No, 5-30 and 0-30 are WAY too light for these engines. Use the Mobil1 15w-50, your engine will be much happier on that.Comment
ive had two mechanics recommend 20w50 for here in south GA. its working great for me, errr my motor.Comment
Because m20s are older engines with larger tolerances than newer engines. Even the S54 recommends special Mobil1 5w-60 I believe. Most new engines from Ford, Honda, etc want 5w30 or even 5w20, but they are built different than our older motors. Especially in warmer climates, you'll want a thicker oil to protect the engine. Using oil that is too thin will accelerate and increase wear.Comment
Sarcasm is a body's natural defense against stupid.
When a man talks dirty to a woman, it's sexual harassment. When a woman talks dirty to a man, it's £3.95 per minute.
"My mother never saw the irony in calling me a son-of-a-bitch." Jack Nicholson"
Old age and treachery will always overcome youth and skill.
Castrol TWS Motorsport, 10W60, yes. But the M52/M54/N5x all use 5W30 - so did the S54, for some time - and I'm not really sure that the M20 has tolerances that are that much higher than the M50s. Of course, it depends on how many miles are on the engine, etc., but I don't know if I'd trade the greater initial wear for the possible greater wear while operating. Of course, in FL/TX/AZ it may be somewhat different.Because m20s are older engines with larger tolerances than newer engines. Even the S54 recommends special Mobil1 5w-60 I believe. Most new engines from Ford, Honda, etc want 5w30 or even 5w20, but they are built different than our older motors. Especially in warmer climates, you'll want a thicker oil to protect the engine. Using oil that is too thin will accelerate and increase wear.Comment
Agreed on the use of 5W-30 for E36 and up generations.
Don't waste your money on synthetic for an M20 though. Non-synthetic Castrol 10W-30 or 20W-50 should be sufficient.Comment
Thank you for clearing things upComment
..::Support FullOpp::..
FullOpp Stickers for sale!
Feedback Thread
Originally posted by Mr. Anderson...one of the most hardcore E30's around. :DComment
