New to E30 325is What OIL?
  • ELVA164
    • 4861
    #106
    Originally posted by itsonlygeorge
    Mobil1 15w50 for summer and 10w30 for winter.
    Mobil 1 10W-30 doesn't have enough ZDDP.
    • ELVA164
      • 4861
      #107
      Originally posted by coldweatherblue
      I've used Castrol GTX 20w-50 in my E30s for the past 16 years.
      Never had a problem that I could say was oil/wear related.
      Reading this thread living in TN (zone 7b) with a freshly rebuilt M20 makes me think about switching to 10w-40 for the summer months but I'm so used to the dub-fiddy it'll be hard..
      If anything, you switch to thinner oil in the winter to help with cold starts. I switched from Mobil 1 15W-50 to Mobil 1 0W-40 and the difference in the cold is pretty striking.
      • Sirjustinderek
        • Jun 2014
        • 143
        #108
        Just picked up a 318 s50 swap. What do you guys recommend?
        • jeffnhiscars
          • Jun 2011
          • 6010
          #109
          Wait....wut ?
          E30s need oil ???
          Alice the Time Capsule
          • dnguyen1963
            • Nov 2011
            • 2648
            #110
            Originally posted by jeffnhiscars
            Wait....wut ?
            E30s need oil ???
            Nah...used cooking oil from McDonald's works just fine.
            • roguetoaster
              Biggus Tippus
              • 7818
              #111
              BMW LL01 probably, just not with a 15k interval. Castrol Edge 0w-40 is a cheap choice ($22 on Amazon for 5qts), M1 is no longer approved, but I'm not worried about a warranty so in to the engine it goes.
              • jeffnhiscars
                • Jun 2011
                • 6010
                #112
                Thanks for sharing that...what a relief
                • scabzzzz
                  Estado de mierda de encargo
                  • 6870
                  #113
                  20w-50 all the way on an M20.
                  • ELVA164
                    • 4861
                    #114
                    Why would you resurrect this thread to say that for no substantiated reason
                    • scabzzzz
                      • 6870
                      #115
                      • ELVA164
                        • 4861
                        #116
                        You just want to watch the world burn, scabz.
                        Zzz.
                        • Zephyyyr
                          • Jan 2018
                          • 47
                          #117
                          Originally posted by Mystikal
                          Ugh, so much misinfo. And it really scares me, because a lot of people are running these stupid oils in E30s and ruining the motors.
                          10W-40 for cold weather (like less than 50F)
                          20W-50 for warm weather (above 50F)
                          This is as per all BMW manuals, including the owner's.
                          Perfectly said. I did hours of research and came up with this as well. If it helps.. After all my research I decided to go with Castrol 03095 GTX 20W-50. I live in Hawaii so 20W-50 was the best choice for me :) Hope this helps!
                          Edit.. Sorry didnt realize this was a older post! Lol.
                          • E30-Ellerman
                            • Oct 2015
                            • 212
                            #118
                            Fuck it, keep the good times rollllllin. This thread has risen from the grave and is alive!!
                            I only drive mine in the spring and summer so stick with Amsoil 20w50 Z-Rod for that zinnnnnnnnnnnnnnnccccccccccccccccccccccc oh yeah.
                            Before turbo though, best bang for buck was that Shell Rotella 15w40, kapow! If I was stock NA M20 Shell Rotella all day!
                            2016 F-150
                            1987 Royalblau 325es B25 turbocharged
                            Build thread here: http://www.r3vlimited.com/board/showthread.php?t=405594
                            • ELVA164
                              • 4861
                              #119
                              Jesus balls, guys. Zephyr, the manual is like 35 years old and isn't relevant in the context of modern oils.
                              Every. Oil. Mentioned. Is. Good. Enough.
