Crank Bolt help?
  • rs4pro3
    • 5808
    Crank Bolt help?
    Ok I'm trying to remove the crank nut on my m30 engine. It's torqued to 325ft/lbs 23 more then the m20 crank bolt. I broke a m20 crank Bolt loose last summer and used the same setup on this engine but I bent the breaker bar I used before. So I went to Home-depot and buaght 2 36 inch sections of 1/2" Schedule 40 Black steel pipe and bent it also. This Nut just won't budge. I also tried my air wrench which goes to 350 ft/lbs but my compressor is undersized for the wrench and it would break it loose either.
    Any ideas of what to do?
    I've soaked the nut at least 6 times with Liquid wrench.
    85 325e 2.7 ITB'd stroker
  • e30Matt
    • 5077
    Hammer and breaker bar? Maybe you can shock it loose with brute force? Maybe a torch to loosen things up?
    Just throwing crap out there.
    • rs4pro3
      • 5808
      I guese I could Torch the bolt to heat it up, but I'd be afraid of all the penetraing oil, and engine oil around the hub and seal to catch fire.
      • kencopperwheat
        King of Kegstands
        • 14396
        Torch around all of the oil and solvents = bad call.
        Originally posted by Gruelius
        • george graves
          • 19996
          Ask M3 Ryan - he knows M30's....
          Originally posted by Matt-B
          • rs4pro3
            • 5808
            I searched Mye28.com and Every one said the Bolt is a Bitch to get off. I even read about a couple people shearing the end of the crank right off :shock:
            If I can't get it tommorow I'll drop it in the trunk and find a large Truck shop to zip it off with a larger air wrench.
            • george graves
              • 19996
              Yea, not a place to use locktite on I guess....
              • rs4pro3
                • 5808
                Well they say it's supposed to be installed with Red loctite and torqued to the exact spec no matter what.
                • george graves
                  • 19996
                  who says that? The mye28 guys?? (if they say so - do it...they know their stuff)
                  • rs4pro3
                    • 5808
                    Yep. I will if I ever get the bolt off. tommorow I'm going to call some truck repair places and see if I drop the block in the trunk if they can zip it off for me.
                    • The Sly
                      • 31
                      I just came across the same problem on one of my M20 block...
                      I finally got it .....I heated it up with a small torch set til it became really hot and then i poored in some cold water to it.
                      Et Voila....worked really good ..it came off really easy with the air gun...
                        • 34839
                        wow, I'm not sure that's a such good idea.. you could really stress the metal by heating it and cooling it really fast, and cause hairline cracks to form.
                        • Jordan
                          • 12913
                          What sly said is standard practice. It shouldnt be a problem.
                          I would suggest using a heat gun instead of a torch tho. Not as fast, not quite as hot, but alot safer.
                          https://mtechniqueabs.com/
                          • aaron_silva
                            • 1785
                            How do you retorque it down? Wont the crank spin before you get to 300+ ft/lbs? Air gun?
                            Aaron
                            • rs4pro3
                              • 5808
                              Rope stuffed in the clyinders, Or Right now I have a piece of chain threaded in where the flywheel bolts and the other end is attached to the block, this keeps the crank firm.
                              I don't have a heat gun handy but I may buy one as I don't want to have a fire on my hands with the torch.
