New Odometer Gears, Still no workie
  • txleadfoot
    • Apr 2006
    • 208
    Recently I replaced broken odometer gears in my non-OBC 318is with Motometer cluster. Everything else in the cluster works fine, including the SI lights and speedometer. I can get the odometer to work by turning the gears by hand and by running compressed air across the main gear. I'm thinking this may be an electrical issue. What think ye?
  • txleadfoot
    • Apr 2006
    • 208
    I found the problem. The small gear for the motor is gone!
    Arghh!
    • houstonh
      • Aug 2007
      • 293
      that should have came in your kit if you got it from the dude from spain on ebay... He is hands down awesome to deal with and far far cheaper than anyone else.
      • lordofthewaters
        • Oct 2005
        • 714
        If you bought a VDO set from Jose it should, I don't know if he has any Motormeters though. I can't really tell which it is from the picture, but I think Motormeter. Anyway the small gear you need is the same for Moto and VDO. He should have one listed for about $7.00 or so. It's a good idea to go ahead and change all the gears at once, and the tougher new white gears will often chew up the older black and orange gears.
        Sarcasm is a body's natural defense against stupid.
        When a man talks dirty to a woman, it's sexual harassment. When a woman talks dirty to a man, it's £3.95 per minute.
        "My mother never saw the irony in calling me a son-of-a-bitch." Jack Nicholson"
        Old age and treachery will always overcome youth and skill.
        • m3_eater
          • 413
          Anyone have a link or contact info? The only gears I've found on eBay are CARR Industries, for a lofty $140 per set!
          E30 24V 6MT SOLD :( - look for it in sunny Miami :)
          • heelN'toe joe
            • Nov 2004
            • 221
            Go directly to Carr Industries website, www.carrindustries.com for a better price on the gears, or just buy the small gear, E1, separetely.
            "aerodynamics are for those who cannot build engines"
            -Enzo Ferrari
            • lordofthewaters
              • Oct 2005
              • 714
              Just ebay search for seller sportevolution
              • deacon96
                • 1
                removing brass shaft
                i just ordered one of the small replacement gears for my motometer odo. the "note" on the Carr Industries website says that the brass shaft must be removed to install the new gear (because the diameter of the hole in the gear is a good bit smaller than the brass surround). i'm assuming the brass thing just unscrews but did not do so easily and i didn't want to force it. can anybody tell me if this is correct?
                • lordofthewaters
                  • Oct 2005
                  • 714
                  Just take a pair of needle nose pliers and squeeze the brass piece. Then after that you should be able to just pull it off. No screwing necessary.
