Timing belt: 128 teeth or 127 teeth???
  • Bimmerfanatik
    • May 2004
    • 5349
    Gotta buy this stuff locally, so I'm stuck with Autozone. They're asking me if I have 128 teeth or 127 teeth for my timing belt.
    Has anyone ever heard this, and how do I find out which I have? Thanks!
  • Spaz
    Crazy Canuck
    • 2276
    it says oh your tenisonor 127 or 128 so that how you know, btw u should replace your tenisonor, and belt at the same time so therfore if u did that you would have a 128 tooth belt.
    Cam .W '91 325is
    Spaz's 1991 Alpine White???? S52 Build Thread...
    • Bimmerfanatik
      • May 2004
      • 5349
      I'm definitely replacing the tensioner, and water pump (see other post). So you're saying if I buy a new tensioner and belt, I should buy the 128 tooth?
      • AdamF 88iS
        • 2051
        The 128 tooth belts are outdated. You need the belt and tensioner for the 127 setup. The tensioner will have Z-127 stamped on it.
        Adam Fogg- '88 M3
        Common sense- It's the new 'gifted'
        • george graves
          • 19995
          Originally posted by Matt-B
          • M-technik-3
            • 18946
            The car had a 127 tooth in it. I had him count after I snipped it with a set of dykes. Gotta change it now. Besides some one had swapped the belt awhile back but it was britttle.
            But the tensioner was not available any where and it didn't have the peg and spring in it. :evil: Non available anywhere either. Will have to go back in.
            • Bimmerfanatik
              • May 2004
              • 5349
              Greg, do you think maybe they used the 127 tooth at the replacement and that's why the cam gear was off a tooth? I was just thinkin about that, maybe the 128 tooth would line it up better...food for thought.
              Think that tensioner will hold until November? No sense in replacing it if the car is getting dismantled for the winter, you know?
              • Dave
                E30 RAT
                • 11675
                I'd order the tensioner and wait a few days to get it done rather than risk it. Bentley says you must use the 127 when you replace it.
                Current Cars
                2014 M235i
                2009 R56 Cooper S
                1998 M3
                1997 M3
                • Bimmerfanatik
                  • May 2004
                  • 5349
                  Well, the job is already done, with original tensioner in place. We used the 127 tooth belt...Greg, did you see that it said only to use the 127 tooth belt? I didn't...that's what we get for not really using it lol.
                  • bwanac
                    • 3354
                    Yes.
