Wheel spacers required?
  • riverdale21
    • Mar 2004
    • 786
    Tirerack is selling some wheels that I like trouble is that upon further inspection the offset is 35mm. Would I need spacers? If so what the hell is Tirerack thinking selling wheels that dont fit?
  • LikeCDoos
    • Jan 2004
    • 2522
    i'm assuming you have a i/e car if so yes they need spacer. 15mm should be about right...don't forget longer lug bots also.
    • MattM20
      • 641
      what is the width of the wheel your looking at?
      • riverdale21
        • Mar 2004
        • 786
        7.5"
        • Sean
          • 5793
          Yea, definately get AT LEAST 10 mm - but I'd suggest 15 mm spacers.
          - Sean Hayes
          • MattM20
            • 641
            Originally posted by riverdale21
            7.5"
            then a 10mm spacer would be ideal
              • 34847
              they would probably fit without spacers (and 205/50 tires), but they would look stupid. 10mm spacers and 225/45 tires would look badass (I'm assuming a 16" wheel diameter here).
              • NC325iC
                • Mar 2004
                • 6565
                tirerack includes everything needed when you buy wheels that fit your car
                spacers bolts everything
                • Brew
                  • 3060
                  I don't think Tirerack recommends wheels that require spacers. et35 wheels will fit w/ 205's, like Nando said, but they would look way better with 10mm spacers and 225's.
                  '91 318is
                  • The Sly
                    • 31
                    Yea like Brew said et35 will fit on 205 and 215 if it is a 17" wheels
                    I have 215/45/17 with et35 17" wheels and it does fit but i got 15mm spacers just in case and they are on the car .
                    I tried it without spacers and it worked but 225 tires will not fit...that's how close it is.
                    • Spaz
                      Crazy Canuck
                      • 2276
                      my oz's are et 35, 17x7.5
                      they fit......barely, get spacers it will look better, trust me.
                      Cam .W '91 325is
                      Spaz's 1991 Alpine White???? S52 Build Thread...
                      • MattM20
                        • 641
                        wow what size tires do you have? i could barely fit my pinky in the gap between my tire and strut housing on 7.5" et25's with 225 tires.
                        • Spaz
                          Crazy Canuck
                          • 2276
                          205/45/r17 :)
                          Cam .W '91 325is
                          • Mystikal
                            Wheel Fitment Expert
                            • 9602
                            Completely untrue. See all those pretty BBS wheels? They ALL require spacers. Same goes for just about everything there except the Kosei K1's.
                            • Brew
                              • 3060
                              Ok, I don't know why I thought that, I must have read something on a similar web site. My bad.
                              '91 318is
