Which is better 4.10 or 3.73 LSD?
  • rcfanatic
    • 490
    #31
    The graph says it's 3700..
    • QUKBMER
      • 8178
      #32
      Originally posted by rcfanatic
      Anybody else have input on this 300 rpm difference? I don't see what all the hoopla is about
      I have a 91 325is with an semiautomatic ;) and when i put a 3:73 in at 75mph i was at 2700 rpm's,put the 4:10 back in was turning 3100 rpm's. I have noticed a 500 rpm difference. My accel from a dig is alot better of course with the 4:10 but i didnt notice any change in mileage either. I drive 100 miles round trip 6 days a week and average 320 to 350 miles to one tank of gas. Now this may vary because most of you are running 5 speeds. I bought this car with an semiauto in it 9 years ago and mostly drive traffic thats why i left it in and havent changed it yet. I have thought of the ideal of leaving in the semiauto and booosting it.
      • priapism
        • 1182
        #33
        Originally posted by nando
        is 80mph really 4000rpm? I don't think it is.. 75 is just over 3500rpm. But my tires are a little oversized.
        Depends on the overall diameter of your wheels and tires as well. Running larger wheels will raise your overall gearing.
        -Sean : 91 Calypso 325i : Castro Motorsports SoCal Spec E30 #33
          • 34847
          #34
          it's not going to change it by 300rpm though, unless you have HUGE (or small) tires (which is what I think you meant, since wheel size has nothing to do with it).
          • z31maniac
            • 17566
            #35
            Post #5 noobs, the difference is approx 12%.
            So if you pull 3000 rpms at 60 with a 3.73, to find out your RPMS at 60 with a 4.10 take 3000 and multiply times 1.12 or ~3360.
            (I made those up, just picked them to illustrate how to figure it out. It's not that hard guys.)
            www.gutenparts.com
            • rcfanatic
              • 490
              #36
              Oh, post #5 is your post!.. So how did you calculate that 12% figure? oh wait.. ;)
              • priapism
                • 1182
                #37
                It's the overall wheel & tire diameter.
                  • 34847
                  #38
                  I know..
                  you'd need tires ~12% too small for it to be that big of a difference. Not to say lots of guys here don't run way undersized tires.
                  My tires are like 1% oversized. It's enough that the speedo actually reads dead on with my actual speed, instead of being over a few MPH.
                  • tjts1
                    • May 2007
                    • 1851
                    #39
                    All the graphs are accurate with the specified tire size. I used a tire size calculator to generate these graphs when I was deciding what diff to use with my M42. I ended up with a 3.64. Best $50 I ever spent on that car.
                    • QUKBMER
                      • 8178
                      #40
                      205-50-16 and 205-50-15 did the same thing with both different wheels and tires.
                      • dashboardmonkey
                        FUCK YOUR WAFFLES
                        • Jun 2008
                        • 6158
                        #41
                        my tires may be slightly undersized
                        -Andy
                          • 34847
                          #42
                          more than slightly, that's like an 8% difference. :p
                          • dashboardmonkey
                            FUCK YOUR WAFFLES
                            • Jun 2008
                            • 6158
                            #43
                            They are pretty wore out, I have done ALOT of big smoky burnouts:pimp:
                            -Andy
                            • 801coppertop
                              • 293
                              #44
                              How do i tell what diff i have now?
                              • Atreus
                                • 1846
                                #45
                                look at the tag on it. it might be dirty. if theres an S on it it'll make you feel good inside. lol.
                                1991 325iC - Mauritsblau sumthin metallic blue. DEAD
                                1992 525i - Silber sumthin sumthin metallic- Rolling again, needs suspension/wheels/brakes/paint.... Fuck you A4S310R; BEAT YOU.
                                1989 325i - Cirrusblau Metallic sumthin sumthin-project - trying to clean up the interior(done), then the body, then a 5spd, then suspension, then..... - [Stolen :| ]
                                1991 325iC - Calypsorot Metallic
                                1994 540i - Granitsilber
                                Originally posted by scabzzzz
                                I've had blunts cock in my mouth, but I'm not gay.
