Ok, so a while back i realized that the left rear window on my foor door iX wasn't working anymore. didn't mind it too much since it was winter, but now it's getting hot.
At first i thought it was the switch. compared the switches with working ones and no luck there. So then i removed the window regulator (91 model so newer electric regulator) and tested it via direct power. The regulator works via the battery but not via switch. Then i tested the line going to the regulator on the door with a known working switch. when the button "up" is pressed, i have power, but when pressed "down" nothing. I am stumped, and i don't know what to check.
All the other windows work fine, and all the cutoff switches are set to work. anything would be great.
T.I.A.
T.I.A.
