Heat range of M42 plugs
  • mgold
    • 709
    Does anyone know the heat range for spark plugs for the M42? A co-worker of mine told me about Brisk spark plugs and I'm thinking about trying them but I need to find out the correct heat range to use.
  • Digitalwave
    is a poseur
    • 6300
    Care to explain that plug to the unknowing (me)? :)
    RISING EDGE
    • AdamF 88iS
      • 2051
      Looks like a surface gap plug. Those are usually for racing only as they will foul quickly on the street daily use. You can go to a hotter plug to avoid fouling so much, but you risk pinging when you go up range.
      Anyhow, your heat range is NGK #6 range.
      Adam Fogg- '88 M3
      Common sense- It's the new 'gifted'
